How to wire 4th JDM fog lights with a standard 4pin realy.
*TITLE SHOULD SAY "4th Gen"* and "relay"
I suck at typing
I did this real quick to help others who are stuck.
I will go back and edit later with pics.
If you are using a standard 4 pin auto relay from radio shack ($2.69) it will not plug into the brown plug like the ABS/Fog one from honda will. You need to make your own harness with some wire and male and female flat connectors to make it connect.
Pin 86 on the relay I grounded to the chasis.
Pin 30 goes into the slot in the brown plug terminal with the red/blue wire going into it.
Pin 87 goes into the slot in the brown plug terminal with the red/green wire going into it.
Pin 85 goes into the slot in the brown plug terminal with the single red/yellow wire going into it.
*nevermind* someone beat me to it. https://honda-tech.com/zerothread?id=1359824
pics and everything
Modified by OEM_ASSASSIN at 12:21 PM 9/25/2005
I suck at typing
pics and everythingModified by OEM_ASSASSIN at 12:21 PM 9/25/2005
i've done this myself the same way, but you've made a mistake...
i"m just going to quote you because i'm lazy
it was already put here though...
DOMAN!EJ8
16
Sep 2, 2009 10:17 PM
EGKREW
12
Feb 28, 2008 04:14 AM
ShakesTheKlown
Mar 29, 2004 09:19 AM
