Why can't anyone help me?
I swapped a d16z6/5spd into my 94 hatch that had a d15b7/auto. I need to know what rewiring needs to be done for my car to run. I have searched and come up with nothing really specific enough. I have installed the motor, trans, manual p28 ecu and know how to wire for vtec, what I need to know is the wiring for the trans swap. Someone help me out please!
Im not sure specifically, but you shouldn't need any additional wiring. If anything you would be taking away wires. Did you try and start it yet?
Only thing needed is to eliminate the "P" lock on the shifter. Even with a 5speed ecu the car thinks its in park because you eliminated the shifter assembly. On the car side harness from the shift selector,you need to connect the thick blk/red and the thick blk/wht wires. Just butt connect these two together. If you do this the car should start. Good luck.
kyliejohn1129
Apr 30, 2012 09:59 PM
DA9Sleeper
Aug 10, 2010 10:44 AM
