valve springs: itr outers w/ portflow inners. good enough 4 bc4's
Old Sep 24, 2005 | 05:43 PM
esohsee's Avatar
Default valve springs: itr outers w/ portflow inners. good enough 4 bc4's
i did a search and came up w/ some stuff but not the info i was looking for. i was wondering if i could use itr outer and portflow inner valve springs w/ the bc4 cams. any help would be appreciatted. thanks.
Old Sep 24, 2005 | 05:56 PM
onepoint6i's Avatar
Default Re: valve springs: itr outers w/ portflow inners. good enough 4 bc4's (esohsee)
they will hold up fine
Old Sep 24, 2005 | 06:41 PM
Nisif's Avatar
I'd look into a different set of valve springs, I was originally running itr outers w/ portflow inners on my bc4s, but I swapped them out for eibach valve springs. According to my head porter, the bc4 lo-cam is pretty aggressive to be running on the itr-portflows, reason why I switched them.
Old Sep 24, 2005 | 09:59 PM
esohsee's Avatar
up
Old Sep 24, 2005 | 11:17 PM
jamessh1's Avatar
Default Re: (esohsee)
rm gen 2 springs and retainers are another option. i'd upgrade to ti retainers for sure though.
Old Sep 25, 2005 | 02:06 AM
oldskool teggy's Avatar
Default Re: valve springs: itr outers w/ portflow inners. good enough 4 bc4's (Nisif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nisif &raquo;</TD></TR><TR><TD CLASS="quote">I'd look into a different set of valve springs, I was originally running itr outers w/ portflow inners on my bc4s, but I swapped them out for eibach valve springs. According to my head porter, the bc4 lo-cam is pretty aggressive to be running on the itr-portflows, reason why I switched them. </TD></TR></TABLE>
if it could hold the vtec cam, how would it not be able to hold the non vtec cam? can you explain?
Old Sep 25, 2005 | 12:35 PM
onepoint6i's Avatar
Default Re: valve springs: itr outers w/ portflow inners. good enough 4 bc4's (Oldskool teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">
if it could hold the vtec cam, how would it not be able to hold the non vtec cam? can you explain?</TD></TR></TABLE>
yes please explain
Old Sep 25, 2005 | 02:51 PM
DonF's Avatar
Default Re: valve springs: itr outers w/ portflow inners. good enough 4 bc4's (onepoint6i)
Who cares, the only people that can answer your question is Portflow. Ask them. Got used outer springs? Toss em.
marks1989civic
Feb 7, 2007 02:20 AM
DC4_MADMAN
Nov 14, 2006 06:24 AM
rcurry14
Sep 19, 2004 11:05 AM
