removing head while motor is out of the car
Old Sep 24, 2005 | 05:07 PM
Kyles ej1's Avatar
Default removing head while motor is out of the car
my d16 is out of the car and im parting it out, what do i need to take off or discnnect?
Old Sep 24, 2005 | 05:29 PM
SuperSteve737's Avatar
take off the timing belt, take off the valve cover, and remove the big bolts between the springs. Head comes off.
Old Sep 24, 2005 | 05:30 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (SuperSteve737)
You can take the intake manifold off too, but its not necessarry.
Old Sep 24, 2005 | 05:44 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve737 &raquo;</TD></TR><TR><TD CLASS="quote">take off the timing belt, take off the valve cover, and remove the big bolts between the springs. Head comes off.</TD></TR></TABLE>
then is taking off the dizzy only for when its in the car?
and the im has 2 bolts that hold it to the block too right?
Old Sep 24, 2005 | 06:31 PM
neutron91's Avatar
Default Re: (93ejay1)
an engine stand makes this alot easier... if you dont have one you will prob have to get someone to hold on to the motor real good to keep it from moving while you loosen the head bolts... they are a bitch to get loose with the motor wobbling around... i swear my arms were so tired after i took my b16 head off with the motor out and on the ground
Old Sep 24, 2005 | 06:37 PM
Kyles ej1's Avatar
Default Re: (neutron91)
shti, yea its gonna be on the ground, i guess ill just have to use a 3 foot pole
ej1252
Oct 28, 2007 03:29 PM
ham
Jul 8, 2006 08:46 PM
realis9
17
Jan 16, 2006 05:15 PM
92JDMcivic
11
Apr 11, 2005 08:25 PM
Layziebtnh055
Apr 13, 2004 07:09 AM
