b18a1 with a hydro tranny possible
Old Sep 24, 2005 | 04:49 PM
drowzysleeper's Avatar
Default b18a1 with a hydro tranny possible
i have a b18a1 that i want to put in my ek, is it possible to put a hydro tranny on it, or would it be easier to convert the car to cable? im kinda new to swaps so i have no clue about this any help would be great thanks.
Old Sep 24, 2005 | 05:09 PM
Default Re: b18a1 with a hydro tranny possible (drowzysleeper)
bump
Old Sep 24, 2005 | 07:56 PM
IMALLSLO's Avatar
Yes,no problem. Just run the hydro flywheel,clutch and pressure plate.
Old Sep 24, 2005 | 08:54 PM
hondaxsimike's Avatar
correctamundo
Old Sep 25, 2005 | 08:04 AM
Default Re: b18a1 with a hydro tranny possible (hondaxsimike)
so i can just use the b18a1 tranny with a hydro pressure plate clutch and flywheel? thats cool. that means i wont have to buy the cable tranny conversion. thanks has anyone done it?
Old Sep 25, 2005 | 08:25 AM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drowzysleeper &raquo;</TD></TR><TR><TD CLASS="quote">so i can just use the b18a1 tranny with a hydro pressure plate clutch and flywheel? thats cool. that means i wont have to buy the cable tranny conversion. thanks has anyone done it?</TD></TR></TABLE>
No no no. You asked if you could put a hydro tranny on a B18a1. We said Yes. Now it sounds like you want to put the original cable tranny on with our suggestion(hydro clutch,flywheel,pressureplate). In an Ek I would suggest the hyro tranny no matter whta block is used.
Old Sep 25, 2005 | 08:45 AM
mmuller's Avatar
Mad Scientist
Default Re: b18a1 with a hydro tranny possible (IMALLSLO)
the only thing you need to change in order to swa tranny's is the clutch disk, everything else will bolt right up.
and if the cable tranny is '92 and up they are plug and play; spline is same size as hydro tranny's
Old Sep 25, 2005 | 04:58 PM
Default Re: b18a1 with a hydro tranny possible (mmuller)
SORRY I WASNT THINKING WHEN I POSTED THAT I KNOW IM GONNA HAVE TO SWAP OUT THE THE CABLE FOR A HYDRO. THANKS FOR ALL YOUR INPUT GUYS HAS ANYONE THAT HADS POSTED ON HERE DONE THIS.
Old Sep 25, 2005 | 08:29 PM
TheLastSpartan's Avatar
Um.. to jump in if I may...
I have a 1990 B18a engine. It came with tranny parts expect tranny itself (i.e. clutch, pressure plate, etc.). Will I be able to bolt up a hydro tranny or will I have to buy new parts? Hate having to buy parts I don't need...
Old Sep 25, 2005 | 09:06 PM
mmuller's Avatar
Mad Scientist
Default Re: b18a1 with a hydro tranny possible (TheLastSpartan)
well...im pretty sure you would want to buy a clutch for an engine with so many years on it..
but besides the point, you would have to buy a clutch disk to be able to use a hydro tranny.
Old Sep 25, 2005 | 09:15 PM
The dude CLAIMS he put a new clutch on it before it was removed form the car so it's going to be wasted. The car was in an accident so they removed everything. Would I also have to remove the pressure plate, etc.? or just clutch plate?
Joey.
Nov 9, 2007 05:07 PM
r6king28
Jul 17, 2006 07:53 AM
Walterronny
May 27, 2006 04:12 PM
jdmCivic925
Sep 23, 2003 10:02 PM
