Gas Mileage....
Was wondering what you guys can run for on a full tank....Stock EF hatchs...My max so far without wanting to run out was 374 miles....Also, how many gallons can i hold? 11???? I dunno....Im a honda noob yall.
I had 340 plenty of times. Never gone past that because the needle was getting low.
The stock tank holds 11.9 gallons I believe, unless if its an Hf, but that is a crx and you said you had a hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boricua8503 »</TD></TR><TR><TD CLASS="quote">Not a hatch but CRX dx with the d15 5spd get 390-400 miles on a full tank.</TD></TR></TABLE>
my STD HATCH, not a CRX, with a d15 put 400 miles on a full tank.
My record with my 88 Hatch Std, when everything was working the wasy it was supposed to, is 410 on a full tank. That was a straight run to San Diego, no stops, from NLV. I was never able to repeat that due to oil and coolant issues, and I haven't done long distance in the hatch since.
i've heard my 89 si will hold over 11 gallons but i've never put more than 10.2 in it and that was belooooooow empty.
i get between 38 and 41 mpg on a regular basis depending on how fast i drive and how much weight i carry. my best has been 43 (long road trip, no cash, 55-60mph) to a low of about 33 (car loaded driving 80 on the freeway)
I go about 315 miles on a tank, but that b/c I never want the needle to go to far down. When I fill up it usually takes about 9 gallons. 35 mpg last time I checked. This is with an LS swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin »</TD></TR><TR><TD CLASS="quote">i have an hf and get 46mpg . when i fill up it always has around 410</TD></TR></TABLE>
NO! Don't Do that!!!!
We only have 10gallon tanks in our HF's...
I fill up early, 275-325miles, though I also average 46mpg. That way I ALWAYS have >1/4 tank of gas.
<1/4 Tank, and all that crap in the bottom of the tank will get sucked up, possibly clogging your fuel filter...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSSG »</TD></TR><TR><TD CLASS="quote">
<1/4 Tank, and all that crap in the bottom of the tank will get sucked up, possibly clogging your fuel filter...</TD></TR></TABLE>
I get at least 300 miles on a full tank. I have an CRX with an HF tank with a b16 motor. When I fill up the tank I only get 9 gallons full. That is running the car until it jerks cause it's so low on gas. 9 gallons later I am full.
CRXBart
12
Sep 9, 2003 11:41 AM
Mr Boston
Apr 20, 2003 12:09 AM
