Disabling fuel system?
I believe i have a blown headgasket, i'm pressurizing my system currently and will test it by cranking the engine with a paper towel laid over the spark plug holes, any water will shoot on the paper towel, but if it's pouring fuel in, i won't be able to tell. My idea is removing the ECU fuse as the best method, correct?
ECU fuse does it, i hadn't gotten a reply as soon as i thought i would so i tried it anyway because i was 99% sure that'd do it. Head gasket seems good from that test, car pulls hard as hell for 8.5 compression, i beat a bolt-on H22A Civic with ease at 10psi (D16Z6), so i can't explain all the smoke (it's a very large amount) out my exhaust and coolant loss, might just be a coincidence and the two aren't related.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote"> or disconnect your injector wires.</TD></TR></TABLE>
Don't do that, you'll risk damaging your ignition coil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Don't do that, you'll risk damaging your ignition coil.</TD></TR></TABLE>
Didn't know that. Thanks.
just unplug the dizzy while ur at it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">just unplug the dizzy while ur at it</TD></TR></TABLE>
Doing all that he's better off just pulling the ECU fuse.
Or did I miss out on some internet sarcasm?
Ananth
Honda Civic (2001 - 2005)
Apr 13, 2024 11:20 PM
BBuncky2
Sep 2, 2008 05:13 AM
BlueShadow
25
Jul 8, 2005 09:43 AM
