Just completed mpfi, rywired! Miss at idle no cel.
Old Sep 24, 2005 | 02:45 PM
chirp the 1-2's Avatar
Default Just completed mpfi, rywired! Miss at idle no cel.
did mpfi using what i think is a si manifold, si rail, injectors ,91 si ecu and dist i bought used.
i bought all new gaskets new pcv all hoses are tight! Im very sure all my vaccum lines are run properly i mocked the detup on the 4th gen sight. Except instead of a y connector on the vaccum coming of the firewall and running both to the tb i had a extra nipple on the back of the manifold so i used it.
I used a rywire harness and integra style resistor box.New cap rotor plugs.
One of the injectors was cracked so i got one from a junkyard out of a 88-91 integra not sure of year but we had to melt down some plastic on the inside of the connector so it would clip.The hose coming from the ash box on the back of the box could be alittle clogged but it didnt do this before.
Car idles perfect no cel no flashing red on ecu! Took it around the block and stomped it no missing at all while driving.
PLEASE help any info or ideas greatly appreciated!! I wanna drive my ef now!!
My friend is leaning towards ignition module in the dist. Heres a link to the mani pic
i found
http://cgi.ebay.com/ebaymotors...sting
Old Sep 24, 2005 | 05:53 PM
rioninja's Avatar
Default Re: Just completed mpfi, rywired! Miss at idle no cel. (chirp the 1-2)
Some things to try:
-Changing out all the injectors with a known good set. The one from the yard may be clogged.
-Check your plugs.
-Are the cap and rotor OEM? some of the aftermarket ones are pretty shitty.
-What ecu are you running? The si ecu will run slightly rich on the d15.
-Did you solder the injector wires?
Old Sep 24, 2005 | 06:17 PM
Default Re: Just completed mpfi, rywired! Miss at idle no cel. (rioninja)
yeah need to check the injectors.
plugs are new but im gonna pull em tomorrow
cap and rotor are oem honda
si ecu but dont think thats gonna cause it
injector wires were part of the rywire harness
Old Sep 24, 2005 | 08:14 PM
Rywire's Avatar
If you had to mod the injector, its prolly not the correct obd... Also, check the tps, and reacliberate it
Ryan
Old Sep 25, 2005 | 04:32 AM
the only mod i had to do to the injector was melt down some tabs on the inside left and right at the top. if it wast right wouldnt something else go really wrong?
Old Sep 25, 2005 | 08:06 AM
Rywire's Avatar
Default Re: (chirp the 1-2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chirp the 1-2 &raquo;</TD></TR><TR><TD CLASS="quote">the only mod i had to do to the injector was melt down some tabs on the inside left and right at the top. if it wast right wouldnt something else go really wrong?</TD></TR></TABLE>
Thats the wrong injector. Use the correct injector and it should solve the problem... You cant mix and match injectors between obd...
Old Sep 26, 2005 | 03:10 AM
cool im sure/hope u are right!!!
Old Sep 26, 2005 | 10:54 AM
Rywire's Avatar
lol, when am i ever wrong...
Im not sayng that thats the cure to the problem(I havent seen your car, and I didint do your swap), but i can say that you dont want to mix obd1 and 0 injectors. Obd1 run on 12volts, and obd0 run on 5.5 after the resistor.
Old Sep 28, 2005 | 04:19 PM
pretty sure the injector was the problem! put a si injector in today and only heard a pop out of the exhaust a couple times in a couple minutes. went out for a ride and had no hesitation.
Old Sep 28, 2005 | 05:42 PM
RasmusRic's Avatar
is there anyway to tell if its a obd0 or obd1?
Old Sep 28, 2005 | 05:43 PM
Rywire's Avatar
Default Re: (RasmusRic)
Yes, the corners are cut in on obd1
Old Sep 29, 2005 | 03:11 AM
0bd 1 injectors have two lines of plastic at the upper right and left corner of the injector.
fallingxlove
Feb 23, 2010 12:25 PM
cornflakes
Mar 21, 2009 05:22 PM
Corporation
Jun 15, 2005 07:29 AM
brbHPR
Jan 9, 2002 04:04 PM
