Need help identifying parts for Ls 5th gear swap
Hey guys i want swap out my 5th gear on my JDM itr trans with an Ls for fuel conservation (88 mile commute) i got a local trans shop that can do the work but i need to bring them the parts.
Anybody help me out with part #s or a site where i can buy the sutff.
My set up
1990 Hatch with Jdm Itr swap
My set up
from what i have researched you will only need the main AND countershaft 5'th gears from a LS tranny.
go to your local acura dealer and order them unless you have a LS tranny kicking around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">from what i have researched you will only need the main AND countershaft 5'th gears from a LS tranny.</TD></TR></TABLE>
You can go to http://www.acuraautomotiveparts.org and print off the illustration of the 5th gears and bring it to your dealer. I will look for the part numbers. That is the same setup I have.
b16_madman
10
Jan 15, 2004 07:39 PM
