Tein SS. What's the specs?
Old Mar 1, 2002 | 01:20 PM
Todd00's Avatar
I said I don't want a title!
Default Tein SS. What's the specs?
Had a friend asking me about the Tein SS coilovers. What's the specs on these (springrate, adjustibility, etc). Also, where do they fall in the Tein lineup?
I know, don't lecture me about Tein But, they are a tad cheaper than the other stuff.
Old Mar 1, 2002 | 01:27 PM
Digital-R's Avatar
Default Re: Tein SS. What's the specs? (Todd00)
Spring rate is 448ibs in front & rear is 336lbs. 16 way adjustable
Old Mar 1, 2002 | 02:38 PM
bhcvc's Avatar
The SS's are Tein's entry-level, most street-oriented damper. There's also the HR, HA, RA, RE, RS, and N1.
Old Mar 1, 2002 | 03:39 PM
GiFF's Avatar
Default Re: Tein SS. What's the specs? (bhcvc)
RE, RE, RE... if u can get a good price on these, they are definitely worth the money...
Todd00's Avatar
Ok, so they are tein bottom line. How does the tein shock compare to something like a Tokico Illumina shock?
Basically he is up in the air about a tokico/GC setup or a Tein setup. He's not too concerned about rust because the car will probably only see nice weather. Might be autoxing it, but that's about all.
Old Mar 1, 2002 | 03:45 PM
mafay2's Avatar
New User
Get the Tein, at least it is a real coilover!!
Old Mar 1, 2002 | 03:47 PM
Nick248's Avatar
200% better than Tokico .... rust is not an issue if you antiseize the thread only where it is being used and then spray the whole shock body w/ wd40. Every 2-3 months do a quick spray. I've had my HA's for a whole year in New Jersey (rain/some snow) and there are absolutly NO signs of rust.
Why not go for the HA's? only $90 more?
-Nick
Old Mar 1, 2002 | 03:57 PM
TodaSi's Avatar
Default Re: Tein SS. What's the specs? (mafay2)
Get the Tien!
I had the HA's on my Civic Si and they worked great, still do. I already got the Tien SS for my Civic hatchback. From what I understand the damper is the same for the HA's and SS's. With the HA's the damper can almost overpower the springs, so I assume the same is for the SS's. Should be a great set-up for the $.
Only drawback is they are steel-bodied. Now that Tien is stateside, they are re-buildable, another added plus.
Old Mar 1, 2002 | 05:15 PM
Todd00's Avatar
Default Re: Tein SS. What's the specs? (TodaSi)
Dang, now you guys are making me want a set. Perhaps I should sell my Tokico/GC combo.
Also, does the 92-95 Civic/94-01 Integra Teins force you to use the ITR rear LCAs, or does tein make them for the USDM rear LCAs?
Old Mar 1, 2002 | 05:44 PM
Dipshit Dan's Avatar
The SS kit is bolt on for all Civics and 94-01 Integras. The RSX kit was just released as well.
projekt90ef
Suspension & Brakes
Aug 25, 2010 09:50 AM
CivicInspired
Honda Civic (2001 - 2005)
22
Jul 18, 2007 08:01 AM
drunknmunkypow
31
Apr 2, 2004 11:19 AM
BADGUYNY
Dec 2, 2003 09:15 AM
d0nkeyxPunch
Jul 9, 2002 08:13 PM
