Blowing seals and burning oil, I think I found a solution...
Old Sep 24, 2005 | 09:54 AM
LSVTEC 91 Civic's Avatar
Banned
Default Blowing seals and burning oil, I think I found a solution...
For a while now I have been burning a small amount of oil, and I can't seem to stop oil pan gasket leaks. The only time I see smoke is when I let off after a 3rd gear redline pull, i'll see puffs of smoke out of the exhaust. I've already replaced a rear main that was destroyed. The cylinder head had a rebuild not too long ago, new valve seals, but the machine shop was unable to replace the valve guides without doing any damage. Compression is an even 280psi on all 4 cylinders, I have yet to do a leakdown. The car still runs great, but the oil leaks **** me off.. I can't stand having a dirty engine.
I came across this and I think I might give it a shot...
http://store.summitracing.com/...earch
Here is the description:
"Increase engine performance by reducing pressure buildup.
These Mr. Gasket crankcase evacuation systems are primarily drag race systems designed to reduce pressure buildup in the engine crankcase. They provide better piston ring seal, less intake charge contamination, and a reduced chance of oil leaks, while increasing your engine performance."
Sounds it would do the trick, what do you all think...
Old Sep 24, 2005 | 10:08 AM
e9's Avatar
e9
Default Re: Blowing seals and burning oil, I think I found a solution... (LSVT3K 91 C1V1C)
that's for a v8 fords and chevy's that it goes into the valvecover grommets something you don't have
Old Sep 24, 2005 | 06:10 PM
onepoint6i's Avatar
how can you not stop oil pan leaks? If you replace the gasket add some hondabond to the designated spots and torque it right, it shouldnt leak at all...you may wanna check your pcv system if the engine is spitting oil out from your new gaskets...
if you want a better ventilation system for your crankcase get this:
http://theoldone.com/components/breather/
Old Sep 24, 2005 | 06:36 PM
d16dcoe45's Avatar
Default Re: Blowing seals and burning oil, I think I found a solution... (onepoint6i)
You can order the pieces individually--I ordered just the check valve that you weld into the header collector--run it to your valvecover--they really only work at all on cars without mufflers. You can also check out http://www.fastbygast.com they have an electric vacuum pump for the crankcase gases--the ProStock bikes use them. It probably works better than the factory ones people pilfer out of older GM cars.
Old Sep 24, 2005 | 06:41 PM
d16dcoe45's Avatar
Default Re: Blowing seals and burning oil, I think I found a solution... (e9)
Also--the Endyn kit is just a modified Moroso can at like twice the price. The only difference is the Endyn can has two ports--the standard Moroso has one. So get a 3/8" npt alum weld fitting from Summit and have it welded on--you will have saved yourself at least $40-$50...
Old Sep 24, 2005 | 07:48 PM
e9's Avatar
e9
Default Re: Blowing seals and burning oil, I think I found a solution... (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">Also--the Endyn kit is just a modified Moroso can at like twice the price. The only difference is the Endyn can has two ports--the standard Moroso has one. So get a 3/8" npt alum weld fitting from Summit and have it welded on--you will have saved yourself at least $40-$50...</TD></TR></TABLE>
wrong
the endyn kit is internally baffled so oil stays in the can while the motor can still keep the vacum lines or use the breather
Old Sep 25, 2005 | 01:34 AM
2k.civic.si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e9 &raquo;</TD></TR><TR><TD CLASS="quote">
wrong
the endyn kit is internally baffled so oil stays in the can while the motor can still keep the vacum lines or use the breather</TD></TR></TABLE>
so for an extra 40-50 bucks u get baffles...just throw some steel wool into the moroso can...done
Old Sep 25, 2005 | 01:39 AM
mjc1055's Avatar
Default Re: Blowing seals and burning oil, I think I found a solution... (2k.civic.si)
I'd rather pay the extra 40 bucks in order not to be ghetto.. Also I'd rather have peace of mind that a manufacturer actually designed the part to work the way it does.. you get what you pay for
Old Sep 25, 2005 | 12:25 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">how can you not stop oil pan leaks? If you replace the gasket add some hondabond to the designated spots and torque it right, it shouldnt leak at all...you may wanna check your pcv system if the engine is spitting oil out from your new gaskets...
I'll take a look at it. I've been through 2 new oil pan gaskets. The first gasket I torqued down to spec with hondabond where it is supposed to be, and the second time I just said **** it and put hondabond all over the gasket. Nothing seems to get rid of these damn leaks.. and I don't want to blow out another rear main.
Old Sep 25, 2005 | 01:22 PM
d16dcoe45's Avatar
Default Re: Blowing seals and burning oil, I think I found a solution... (mjc1055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">I'd rather pay the extra 40 bucks in order not to be ghetto.. Also I'd rather have peace of mind that a manufacturer actually designed the part to work the way it does.. you get what you pay for </TD></TR></TABLE>
How hard is it to design a catch can? So figure out a way to baffle the Moroso can-without something like steelwool getting sucked out of it--I wouldn't buy the Endyn can on principle....Not to mention I already have a standard Moroso can hooked up. Also--does anybody have proof or pictures of this "baffle" in the Endyn can? The Endyn site makes not mention of it whatsoever.
Old Sep 25, 2005 | 05:29 PM
onepoint6i's Avatar
Time is money in my eyes, your gonna spend more time/gas trying find all the neccasary hardware and what not...You pay for the convenience of the product as a whole...
To each their own, If you have the time and availibility of hardware to make your own product, then more power to you..If not (like myself) i would go with the endyn and be done with it...
relentlesstech
Jun 22, 2016 11:18 AM
rdssk8rcs1
Oct 20, 2011 01:53 PM
mike93eh2
14
Aug 13, 2006 05:33 AM
user 98292739
Feb 21, 2005 12:01 PM
c1hatch
Jul 28, 2002 07:27 PM
