Differential : Removal and Install *SOHC* I Need a Guide *HELP*
Old Sep 24, 2005 | 07:59 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Differential : Removal and Install *SOHC* I Need a Guide *HELP*
I was quoted over $400 today by my local tranny shop to swap my OEM differential with my OBX LSD. Toooo much for my budget so I wanna try and do it myself. Ive got a spare tranny that has something inside blown that I can do a test run on I guess.
I couldnt find a sinlge bit of info anywhere on a SOHC differential swap. I need a complete guide, I know nothing about transmissions, literally nothing other than the clutch flyshweel and throwout bearing. SO I need a serious step by step walk through and any special tools needed.
Thanks guys
Old Sep 24, 2005 | 04:59 PM
PINKS's Avatar
Default Re: Differential : Removal and Install *SOHC* I Need a Guide *HELP* (CanadianMade)
bump for a nice walkthrough
Old Sep 24, 2005 | 05:06 PM
Honda Crx's Avatar
well you know pull the tranny.. pull the 3/8 plug (not the drain) all the 12mm bolts going around the tranny.. now with the 3/8 pulled spread the circlip and pull the case apart.. now with the case off pull the 19mm bolt and the gold twelves blah blah you know what i cant explain just watch what your doing and take pictures and see where everything goes
Old Sep 24, 2005 | 05:14 PM
PINKS's Avatar
Default Re: Differential : Removal and Install *SOHC* I Need a Guide *HELP* (Honda Crx)
haha, you cant just have zero tranny experience and open one up and expect to successfully install an aftermarket unit.
Im cheap so I want to know what things I can reuse and such
I need an actual Honda guide or someone else exptremely detailed version of the install
Thanks
Old Sep 25, 2005 | 05:48 AM
PINKS's Avatar
Old Sep 25, 2005 | 06:29 AM
non-VTEC's Avatar
you need to have someone with experience help you on this job.
if you don't know or don't have the service manual then you will get lost trying to take it apart and even more so trying to put it back together.
Old Sep 26, 2005 | 04:38 AM
PINKS's Avatar
znoj
Nov 4, 2010 03:10 AM
530guy
Jul 14, 2006 05:50 PM
egizzle8
Feb 13, 2005 04:49 PM
jlamaster
Nov 22, 2003 05:11 PM
Mugen_R
Oct 18, 2001 05:51 AM
