clutch vibrating when engaging in first gear?
Old Sep 24, 2005 | 07:32 AM
the.hamburglar's Avatar
Default clutch vibrating when engaging in first gear?
i have a new exedy stage 2 cermetallic with an aftermarket lsd. now when i am stopped at a light and then go the clutch is making a nasty vibrating sound only in first gear and then low rpm in all gears? is this going to go away? or is my clutch just so kick ***? bearings were all replaced. does my clutch need to be bled?
Old Sep 24, 2005 | 10:37 AM
Kendall's Avatar
Clutch chatter is typical of more agressive clutches. Sometimes you'll get a clutch that does it and sometimes you won't. The last two aftermarket clutches I've had chattered to some degree or another.
Old Sep 24, 2005 | 12:25 PM
1700anddroping's Avatar
Default Re: (Kendall)
it made the same noise on a customers car.is it the 4 puck sprung.but it has since went away....this clutch for the street is crazy aggressive.
harv
Old Sep 24, 2005 | 05:34 PM
Default Re: (1700anddroping)
its the exedy stage 2. grabs like crazy. ill give it 600 miles. it better go awauy
JDM_Certified
Transmission & Drivetrain
Oct 7, 2010 08:56 AM
Moemers
Honda S2000
12
Nov 27, 2006 06:58 AM
slowj
Jan 18, 2004 06:25 AM
echo999
Dec 17, 2002 01:57 PM
