92 Prelude Help...Won't Start
hey guys i was wondering what you think might be the problem with my prelude. It's the h23 motor. For some reason, it does not want to start. The car cranks and there is fuel going into the rail. What could be the problem?
Hi. I have the same problem. I have a 1993 with h23a motor I installed a used Jap. engine car runs great all of a sudden I experienced a crank no start problem during hot summer days. So I would let interior cab cool then start up. I tested everything and I taught maybe fuel pump was getting lazy so I replaced. Did not do a thing same problem all over. If you found a solution please let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fscot »</TD></TR><TR><TD CLASS="quote">Main relay has gone bad.</TD></TR></TABLE>That's what was wrong with mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "fscot" »</TD></TR><TR><TD CLASS="quote">Main relay has gone bad</TD></TR></TABLE>i would say the same too, but he said there is fuel up to the fuel rail, and the fuel pump is hooked up to the main relay. what is the fuel pressure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sAnD***** »</TD></TR><TR><TD CLASS="quote">um, i think we need some more details, it could be a ton of things, are you getting a spark?</TD></TR></TABLE>
can't be the main relay if fuel is getting to the rail
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">
can't be the main relay if fuel is getting to the rail</TD></TR></TABLE>
Main relay does two things. Read my above post for details.
if you have trouble starting sometimes it is because you are using regular gas. if it doesn't start at all it could be many of thing mostliklly sounding from yours can be the relay.. but check into all your grounds sometimes the simplest thing is your biggest problem...
bigwodeeb
Apr 5, 2007 09:41 AM
littlestroker
Mar 30, 2005 07:53 PM
