Over Tighten Oil Pan bolts?
Old Sep 23, 2005 | 05:46 PM
DjTrex's Avatar
Default Over Tighten Oil Pan bolts?
Is it possible to over tighten the bolts on the oil pan? it looks like the gasket is squeezing out the edges of the oil pan. should i loosen them or do i need to start over and do it again or just leave it?
Old Sep 23, 2005 | 06:05 PM
PrettyLude's Avatar
just leave it and see if it leaks
Old Sep 23, 2005 | 06:24 PM
Muckman's Avatar
Moderator in Chief
Default Re: Over Tighten Oil Pan bolts? (DjTrex)
torque it to spec and forget about it.
Old Sep 23, 2005 | 11:01 PM
DjTrex's Avatar
where would i find such specs?
Old Sep 23, 2005 | 11:08 PM
mmuller's Avatar
Mad Scientist
Default Re: (DjTrex)
in a service manual, for basic service you can get away with the one they sell at autoparts sore; for more complex tasks your going to want to use helms.
8lb-ft is the spec for oil pan bolts/nuts
Old Sep 24, 2005 | 03:13 AM
non-VTEC's Avatar
if the gasket its getting crushed and squeezing out the sides your to tight.
i found that 8-10 ft/lbs might be a little to tight (sometimes). i like to used 30-40 in/lbs and i never had a problem with them leaking.
Old Sep 24, 2005 | 09:21 AM
h22isTehsex's Avatar
Id find the stock torque specs, on my h22 i tightened them handtight, then another half rotation, and one of them worked itself out halfway..
Old Sep 24, 2005 | 01:40 PM
hondaxsimike's Avatar
it is definitely possible to overtorque the oil pan. and in some cases it will cause it to leak. definitely follow the specs.
EK9JSPEC
Apr 20, 2012 01:06 AM
Rhood
Feb 7, 2007 05:30 PM
4gludy
May 23, 2006 07:08 PM
hugh_jazz_sponer
Aug 5, 2004 12:54 PM
oemDC2
Apr 30, 2004 03:20 AM
