Car shaking.. still waiting for an alignment
I just recently replaced my inner and outer tie rods. and i was driving the car today to get an alignment the steering wheel was shaking quite a bit would a bad alignment cause this i just wanna be sure there is no other problems
From: With my POS D15B2, Whereever whenever, United States
Three things
1)alignment
2)Bad tires
3)Steering column
It can be a combination of both and vice versa, its you're deal
1)alignment
2)Bad tires
3)Steering column
Tires just balanced, New Wheel bearings, New pads and rotors, new inner & outer tie rods, Ball joints. i need an alignment bad cause the steering wheel is way off. so im just going off the assumption its the alignment
check your break your steerin wheel will shake if you need a brake job or if you lugs are loose. but it will pull if you need to get it aligned
I had that. So I got my alignment.
"Hey your right front axle needs replacement."
Got that fixed.
"Oh yeah, that squeeling, thats your breaks needing replacing, and we'll resurface your rotors."
But with how I drive, its probably my tires.
So it could very well be your tires.
Got that fixed.
Because i was tired of replacing stuff and when i decided to do my suspension i did replaced everything just for my reassurance.
BTW the alignment fixed the shaking problem
