Buying a CRX...it's throwing codes and running funny...should i buy it?
Old Sep 23, 2005 | 10:33 AM
sidewayz32's Avatar
Default Buying a CRX...it's throwing codes and running funny...should i buy it?
I went and looked at the CRX i'm thinking about buying. It runs and drives pretty good except for a few things.
Passenger side rear caliper is toast. it drags and squeals while driving.
shifter is EXTREMELY hard to get in and out of gear, at first i though shifter bushings, but the car has a new clutch, and i'm thinking the clutch pedal just isnt adjusted right...
here's the biggie, it's THROWING A CODE 9. which according to the FAQ means #1 cylinder position. the guy said the car needs a distributor, could the distributor cause this code?
also, when the car is warm, at idle, it will jump up to about 1500 rpms and then sharply drop to about 300 and repeat this. could the disrtibutor cause this?
thanks
Old Sep 23, 2005 | 10:37 AM
SiR Inspired ED7's Avatar
Default Re: Buying a CRX...it's throwing codes and running funny...should i buy it? (sidewayz32)
i member i had that code, i just replace my dizzy since i had one sittin down and car ran like new
but than again how much does this guy want for the car?year?miles?rust?
Old Sep 23, 2005 | 10:38 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">
but than again how much does this guy want for the car?year?miles?rust?</TD></TR></TABLE>
What is the price on it then we can tell you if you should buy.
Old Sep 23, 2005 | 10:56 AM
b18_crx's Avatar
Default Re: Buying a CRX...it's throwing codes and running funny...should i buy it? (CRX Toad)
depending on how much it is then id buy it
Old Sep 23, 2005 | 11:38 AM
sidewayz32's Avatar
Default Re: Buying a CRX...it's throwing codes and running funny...should i buy it? (b18_crx)
its a 90 si w/ 213k miles
he's asking 1500 OBO and it's been for sale for about a month
rust on rear driver fender, about 6 inches long
car has also been sitting since may apparently
top end was also rebuilt about 6 months ago
has new clutch, tires, head gasket, water pump, timing belt, alternator, and cams
Old Sep 23, 2005 | 01:07 PM
sidewayz32's Avatar
how much should i offer for this car?
Old Sep 23, 2005 | 01:53 PM
superbeastcrx's Avatar
Default Re: (sidewayz32)
you shouldn't, i should! just playing i would try 900-1000 tops
ADAMnQuickRDX
May 7, 2009 11:30 AM
turboblack2door
Sep 2, 2008 01:10 AM
UNDER PRESSURE
Nov 4, 2007 10:25 AM
kamakaze1
Jul 28, 2006 11:06 AM
dank24
Jun 12, 2006 07:17 AM
