How to set timing with no TB cover?
Old Sep 23, 2005 | 10:08 AM
Ekay Jay's Avatar
Default How to set timing with no TB cover?
I have a ls/vtec in my 93 DA. I dont have a lower timing belt cover on my motor and would like to know what marks i can go by for setting the timing. Im pretty sure that u line the red mark on the crank pulley up with the timing belt then set the cam gears up. But im not 100% thats right....
Old Sep 23, 2005 | 11:26 AM
JH4DB858's Avatar
Default Re: How to set timing with no TB cover? (JdM DA InTeGrA)
Its kinda hard.. But there is a lil mark on the block above the crank pulley. Good luck setting your timing
Old Sep 23, 2005 | 11:28 AM
Rajin's Avatar
Default Re: How to set timing with no TB cover? (JH4DB858)
If all else fails, contact me and I'll come help you out.
Old Sep 23, 2005 | 11:43 AM
Ekay Jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DB858 &raquo;</TD></TR><TR><TD CLASS="quote">Its kinda hard.. But there is a lil mark on the block above the crank pulley. Good luck setting your timing </TD></TR></TABLE>
Yea u cant really see that mark with the motor in the car
Old Sep 23, 2005 | 12:02 PM
DAguyLS's Avatar
Default Re: How to set timing with no TB cover? (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">If all else fails, contact me and I'll come help you out.</TD></TR></TABLE>
nice guy!!
Old Sep 23, 2005 | 12:12 PM
Ekay Jay's Avatar
Pm sent
Old Sep 23, 2005 | 02:22 PM
Sam92Teg's Avatar
Use the white mark on the crank pulley matched to the oil pump pointer while cam gears up marks are up to set cam timing with crank pulley. The white line is to the right of the 3 ignition timing marks.
Red mark on the crank pulley is used when using a timing gun to set ignition timing. Use some spray cleaner and a bright light to see the marks.
Old Sep 23, 2005 | 02:37 PM
Ekay Jay's Avatar
I have the cam timing set. But now how am i supose to set the ingnition timing when i dont ahve a mark to go by??
Old Sep 24, 2005 | 06:58 PM
Sam92Teg's Avatar
Your cam timing isn't set correctly until the crank is in the right position, white mark on the oil pump/cover pointer or #1 piston at Top Dead Center (TDC). If you do indeed have it timed properly, look at where the white mark on your crank pulley meets the oil pump. There should be a mark you use to set your timing on the oil pump as well as the lower cover which goes over your oil pump.
Bad things can happen when not using a lower cover, your belt is too important to leave nakid. One little rock could ruin your day.
Old Sep 24, 2005 | 07:07 PM
tegasaurus's Avatar
Default Re: How to set timing with no TB cover? (Sam92Teg)
yes.
just set psiton #1 at TDC, crank it, and if air is exiting the exhaust, then you got it right, if air is coming out of your air filter, then its 180 off.
Old Sep 25, 2005 | 11:44 AM
Ekay Jay's Avatar
Default Re: How to set timing with no TB cover? (tegasaurus)
I have already fixed the cam timing, I had it right to begin with. Now i just need to figure out how im gonna set the ignition timing
Old Sep 25, 2005 | 01:48 PM
Old_Honda's Avatar
I hate to say it, but you'd probably be better off putting the lower cover back on, not only so you can set the timing but also to protect the belt.
benitom
11
Jul 13, 2008 06:31 PM
NSfit
Nov 26, 2006 07:34 PM
JediKGB
Dec 4, 2005 02:29 PM
impr323
Sep 25, 2005 09:05 AM
_Endless_
May 12, 2003 07:22 PM
