Gas Smell Within Car
1990 Civic Si
When i park it in my garage over night, i get in it and immediately i get an over powering smell of gasoline. Not pleasant. Air freshener only changed the smell to something horrible
any ideas on what could be causing this?
i called my friends dad
he said it may be from a small leak in the gas tank.
turns out its right, i can smell it when i get underneath the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadianMade »</TD></TR><TR><TD CLASS="quote">might wanna figure it out before you drive it, patch kits are cheap though</TD></TR></TABLE>
where might I buy a patch kit?
and its definately the gas tank, i just have to pinpoint the exact location
if you end up dropping the tank might as well replace the pump while its off.
kinda like when you do a timing belt, its best to do the tensioner and water pump cuz its easy at that point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spada »</TD></TR><TR><TD CLASS="quote">1990 Civic Si
any ideas on what could be causing this?</TD></TR></TABLE>
Is the carpet on the left side of the drivers footwell soaked with gas? The fuel line tends to corrode through there.
