1992 honda civic
very possible the bearings in the dizzy are going... I would get that checked asap. They dizzy in hondas has a nasty habit of seizing and causing the t/belt to jump. Get it checked. A way for you to look is, pop the cap off and look for a red dust, if you see any at all, the bearings are f*cked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 »</TD></TR><TR><TD CLASS="quote">very possible the bearings in the dizzy are going... I would get that checked asap. They dizzy in hondas has a nasty habit of seizing and causing the t/belt to jump. Get it checked. A way for you to look is, pop the cap off and look for a red dust, if you see any at all, the bearings are f*cked.
What he said. My Civic did the same thing with the exception of the timing belt skipping. I wouldn't drive it because you run the risk of it shitting on you while driving. Mine went out during a downshift in front of a semi.
</TD></TR></TABLE>What he said. My Civic did the same thing with the exception of the timing belt skipping. I wouldn't drive it because you run the risk of it shitting on you while driving. Mine went out during a downshift in front of a semi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johns300m »</TD></TR><TR><TD CLASS="quote">So it is best to have the car towed?</TD></TR></TABLE>
That seems to be the general consensus wouldn't you think?
ijjz
Nov 28, 2006 04:47 AM
stocker2shocker91
Dec 28, 2005 09:16 AM
