rear camber WASHER trick!!!! (in C++ Programming) lol
task main();
int n;
if joo know what the rear camber washer trick is
then
plz tell me what is the size of the bolts that i need to buy to replace the short
one;
else
say hi and thanks to you from my side;
end
int n;
then
one;
else
end
yeah thanks for all the hi's hahahah
but the prolbme is that i cant take to the hard ware store since i wont have a ride if the bolt is off the car... lol coz im diong it early moring.. no pals wake up early... grrr
and thanks for the creative remarsk.. haha i woke up at 5.30 in the moring to give my mother a ride to the doc.. anywyas thanks for the help guys !!! peace !!
and hi all
so plzzz someone tell me the exact size thanks
and hi all
Do you have any nuts just sitting around? I know I've got left over bolts from a lot of stuff I've done. Maybe you can find one that fits the bolt and then go to a hardware store to find another bolt that'll fit the nut.
Sorry I can't be of more help. Just trying to help out as much as I can.
Have any friends that could give you a lift?
What i do is, if it doesnt come with the camber kit. Take bolts to a local bolt place (one of those spots that have every bolt known to man, or theyll make it for you) and get them there.
But SL says its a 10x30 So you might want 10x50 but the downside to that is it doesnt tell you the pitch and they wont know what your talking about at a bolt shop. Call Honda and as for the pitch. I think it should be 1.5 im not sure though, because 1.0 and 1.25 is way to fine for it if i remember correctly.
If you want to just buy a bolt and washer kit for $20, here's a linkhttp://www.passwordjdm.com/pro...lated Other than that I have no idea bout the sizes.
1. you have a semicolon after task main()
2. need brackets for the main function
3. parenthesis around the if test
4. semicolon after end, pretty sure, havent messed with C++ in years
tsk tsk.
anyway hi.
tsk tsk.
anyway hi.
Why not ask it in VB.Net as well?
Private Sub open(ByVal sender As Object, ByVal e As System.EventArgs) _
Handles open
MessageBox.Show("If you know the rear camber washer trick, Please share it with me.", _
MessageBoxButtons.YES.NO)
End Sub
Private Sub YES_Click(ByVal sender As Object, ByVal e As System.EventArgs) _
Handles Yes.Click
MessageBox.Show("Thank you for telling me!", _
MessageBoxButtons.OK)
Private Sub NO_Click(ByVal sender As Object, ByVal e As System.EventArgs) _
Handles NO.Click
MessageBox.Show("Thanks anyway!", _
End Class
Handles open
End Sub
Handles Yes.Click
Handles NO.Click
End Class
90gs
Apr 29, 2005 09:25 AM
spencedogg
14
Dec 7, 2003 01:14 AM
FourthGenHatch
11
Oct 1, 2002 07:00 PM
