rear camber WASHER trick!!!! (in C++ Programming) lol
task main();
int n;
if joo know what the rear camber washer trick is
then
plz tell me what is the size of the bolts that i need to buy to replace the short
one;
else
say hi and thanks to you from my side;
end
int n;
then
one;
else
end
Re: rear camber WASHER trick!!!! (Falkien)
Longer than the bolt you have?
If you can take it to a hardware store with you and then find a bolt with the same thread size, but one that's longer.
Re: rear camber WASHER trick!!!! (nota-eg)
yeah thanks for all the hi's hahahah
but the prolbme is that i cant take to the hard ware store since i wont have a ride if the bolt is off the car... lol coz im diong it early moring.. no pals wake up early... grrr
and thanks for the creative remarsk.. haha i woke up at 5.30 in the moring to give my mother a ride to the doc.. anywyas thanks for the help guys !!! peace !!
and hi all
so plzzz someone tell me the exact size thanks
and hi all
Re: rear camber WASHER trick!!!! (integraver)
Do you have any nuts just sitting around? I know I've got left over bolts from a lot of stuff I've done. Maybe you can find one that fits the bolt and then go to a hardware store to find another bolt that'll fit the nut.
Sorry I can't be of more help. Just trying to help out as much as I can.
Have any friends that could give you a lift?
What i do is, if it doesnt come with the camber kit. Take bolts to a local bolt place (one of those spots that have every bolt known to man, or theyll make it for you) and get them there.
But SL says its a 10x30 So you might want 10x50 but the downside to that is it doesnt tell you the pitch and they wont know what your talking about at a bolt shop. Call Honda and as for the pitch. I think it should be 1.5 im not sure though, because 1.0 and 1.25 is way to fine for it if i remember correctly.
Re: rear camber WASHER trick!!!! (Luserkid)
If you want to just buy a bolt and washer kit for $20, here's a linkhttp://www.passwordjdm.com/pro...lated Other than that I have no idea bout the sizes.
1. you have a semicolon after task main()
2. need brackets for the main function
3. parenthesis around the if test
4. semicolon after end, pretty sure, havent messed with C++ in years
tsk tsk.
anyway hi.
tsk tsk.
anyway hi.
Re: rear camber WASHER trick!!!! (in C++ Programming) lol (integraver)
Why not ask it in VB.Net as well?
Private Sub open(ByVal sender As Object, ByVal e As System.EventArgs) _
Handles open
MessageBox.Show("If you know the rear camber washer trick, Please share it with me.", _
MessageBoxButtons.YES.NO)
End Sub
Private Sub YES_Click(ByVal sender As Object, ByVal e As System.EventArgs) _
Handles Yes.Click
MessageBox.Show("Thank you for telling me!", _
MessageBoxButtons.OK)
Private Sub NO_Click(ByVal sender As Object, ByVal e As System.EventArgs) _
Handles NO.Click
MessageBox.Show("Thanks anyway!", _
End Class
Handles open
End Sub
Handles Yes.Click
Handles NO.Click
End Class
90gs
04-29-2005 09:25 AM
spencedogg
14
12-07-2003 01:14 AM
FourthGenHatch
11
10-01-2002 07:00 PM
