Ok i have a
Old Sep 23, 2005 | 04:24 AM
GreenEX's Avatar
Default Ok i have a Vtec ?
OK so my buddy has a 93 hatch with at b16a motor and a 94 integra dash. The problem is His Vtec wont work. We wired a vtec controller and it still wont work. He thinks its something in the dash. Which i thought as long as power is going the controller should turn vtec on. Does anyone have an idea? We check to be sure there is power going to the solenoid. Thanks if anyone has an idea of what to check for.
Old Sep 23, 2005 | 05:13 AM
C2daIzZle's Avatar
i know it sounds dumb & obvious, but did you check fuses?
Old Sep 23, 2005 | 05:32 AM
vc's Avatar
vc
Default Re: (C2daIzZle)
1st How do u know ur vtec doesn't work??
Old Sep 23, 2005 | 07:16 PM
GreenEX's Avatar
Default Re: (vc)
Well its not my car he said he checked the fuses. We know its not working because when it was in his coupe you could hear it. now in the 93 hatch there is no sound plus the power begins to drop off in high rpms.
Old Sep 24, 2005 | 10:50 AM
96ls's Avatar
Default Re: (GreenEX)
is vtec wired up properly?
Old Sep 24, 2005 | 10:54 AM
EG93si's Avatar
Default Re: (96ls)
wiring in dash screwed up, my 2cents, we know you checked for voltage on the sel but did you get any? kinda left it in the air?
KURUPTinc's Avatar
Default Re: (96ls)
wire it direct to a switch and ground or run a wire from the power side to the battery. with the car off touch it to a twelve volt source (battery) and make sure the solenoid clicks.
Old Sep 24, 2005 | 11:17 AM
wtf mate's Avatar
I dont see how the dash would have anything to do with vtec.
In fact, it wouldnt. Did he touch the engine harness?
does the cluster work? if so any CEL?
Oil level ok?
CHeck wiring for vtec solenoid.
Old Sep 24, 2005 | 11:35 AM
infrontofu's Avatar
Default Re: (KURUPTinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURUPTinc &raquo;</TD></TR><TR><TD CLASS="quote">wire it direct to a switch and ground or run a wire from the power side to the battery. with the car off touch it to a twelve volt source (battery) and make sure the solenoid clicks.
Old Sep 24, 2005 | 02:15 PM
EG2Driver's Avatar
Default Re: (infrontofu)
might sound dumb.....and maybe it is, but VTEC works only at certain engine temperature...if its not warm enough, it wont engage.
Old Sep 24, 2005 | 03:43 PM
GreenEX's Avatar
Default Re:
I'm not sure of the volts the wiring harness has been messed with but i have check every thing with it and its good. the dash works no speed though. I know about the temp and we made sure of that. oil is proper. and no CEL. Im gonna try the batt. to see if i can hear it engage. I didnt think of that. Ill keep u posted.
Thanks for the info so far.
Old Sep 25, 2005 | 06:10 AM
EG93si's Avatar
Default Re: Re: (GreenEX)
need speedo for vtec to kick in, it needs to go above like 19 or something stupid. damn im good
Old Sep 25, 2005 | 06:17 AM
robbie_R(eg6)'s Avatar
Default Re: Re: (EG93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si &raquo;</TD></TR><TR><TD CLASS="quote">need speedo for vtec to kick in, it needs to go above like 19 or something stupid. damn im good </TD></TR></TABLE>
i can engage mine in idle but that was with a vafc, its not a good thing to do but i can do it
Old Sep 25, 2005 | 09:48 AM
nota-eg's Avatar
Default Re: Re: (robbie_R(eg6))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robbie_R(eg6) &raquo;</TD></TR><TR><TD CLASS="quote">i can engage mine in idle but that was with a vafc, its not a good thing to do but i can do it</TD></TR></TABLE>
With a stock ECU you need to be at operating temperature and at 20+ mph for vtec to engage.
You said he is using a VTEC controller, correct? Was he using the controller in his old car?
Old Sep 26, 2005 | 03:56 AM
GreenEX's Avatar
Default Re: Re: (nota-eg)
yeah he has a vtec controller and the same controller was in his old car. Even with the controller do you still need the speed to work? i thought that no matter what the controller would tell vtec to kick. I sold this vtec controller to him a while ago. I had it in my civic and if it was cold still the vtec would turn one would end up throwing a vtec code but i would work no matter. thats why im having a prob with this. i figure it should be working.
Old Sep 26, 2005 | 02:29 PM
sloweh3's Avatar
Make sure the vtec controller is hooked up properly. My roomate bought a 94 eg hatch w/ a b16. Vtec was working until the guy riding with him accidentally bumped the controller. Vtec stopped working. Just make sure everything is hooked up properly.
Old Sep 26, 2005 | 02:44 PM
PatMFriley's Avatar
check the wiring
Old Oct 26, 2005 | 06:36 PM
GreenEX's Avatar
Default Re: (PatMFriley)
Ok so i asked about this awhile back and finally got time to go over and mess with it. so the car is a 93 hatch. and the old owner had put an h22 motor in it. he mess with lots of stuff to make it work. any way i figured out the vtec prob today. I guess the h22 wiring harness to the motor has the vtm signal wire and the vtec wire swapped compared to a civic. those two come to find out were in opposite places. so we switched them and how its all good. the thing finally drives like it should well kinda. its a long work in progress. Just keeping everyone posted.
Thanks for any info and help that was given.
shoklid
Feb 28, 2013 01:10 PM
AnAccordIsForever
Jun 3, 2008 03:27 PM
Evil_Twin
Mar 10, 2007 09:24 PM
d16EK
Dec 5, 2005 09:29 AM
Eg6_JDM
Apr 26, 2002 10:27 AM
