Honda S2000 Honda S2000
hardtop rattles, wat should i do?
Old Sep 22, 2005 | 11:38 PM
myBebe_s2K's Avatar
Default hardtop rattles, wat should i do?
hey guys, just a quick question for all you out there with hardtops. does your hardtop or hardtop hinges rattle when you hit bumps? mine does (but is it because my car is lowered??) It gets annoying so whats the best way to stop it or reduce the rattling? thanks for your help.
Modified by myBebe_s2K at 9:15 AM 9/23/2005
Old Sep 23, 2005 | 04:49 AM
HXMan's Avatar
Default Re: hardtop rattles, wat should i do? (myBebe_s2K)
Check the TSBs. They have a list of them on s2ki.com
Old Sep 23, 2005 | 07:31 AM
Nishant's Avatar
Default Re: hardtop rattles, wat should i do? (HXMan)
prob just needs some adjustment. did you install it or dealer?
Old Sep 23, 2005 | 05:47 PM
vanos_pusha's Avatar
Default Re: hardtop rattles, wat should i do? (Nishant)
ah man, it's ruined...i'll offer you $150! lmk...
Old Sep 23, 2005 | 11:47 PM
s2kboy03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myBebe_s2K &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, just a quick question for all you out there with hardtops. does your hardtop or hardtop hinges rattle when you hit bumps? mine does (but is it because my car is lowered??) It gets annoying so whats the best way to stop it or reduce the rattling? thanks for your help.
Modified by myBebe_s2K at 9:15 AM 9/23/2005</TD></TR></TABLE>
nope mine doesn;t but everything else rattles inside haha....which HT do u have?
Old Sep 24, 2005 | 06:21 AM
Nishant's Avatar
Default Re: hardtop rattles, wat should i do? (s2kboy03)
oem...check the stoppers. if you play around with it, you find out whats rattling
Old Sep 24, 2005 | 03:03 PM
Mr. Projekt's Avatar
* B A N N E D *
Isnt there a piece of rubber trim that lines the bottom edge of it, or does it just cover the windows?
Old Sep 24, 2005 | 07:49 PM
myBebe_s2K's Avatar
Default Re: hardtop rattles, wat should i do? (Sideways2000)
its an oem hard top from the dealership.. a fren installed it. seemed okay at first but the hinges just keep rattling soon after the ground controls were installed so its like an inch and 1/2 inch off the floor (seems like a bad idea). is there some kinda silicone or padding i can buy to reduce sound? Theres a black lining of padding under the top, but it gets in the way cause when i roll my windows up, it kinda gets stops the windows from rolling all the way up...
Old Sep 24, 2005 | 08:04 PM
cornercompacts's Avatar
turn up your stereo
Old Sep 24, 2005 | 09:26 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myBebe_s2K &raquo;</TD></TR><TR><TD CLASS="quote">its an oem hard top from the dealership.. a fren installed it. seemed okay at first but the hinges just keep rattling soon after the ground controls were installed so its like an inch and 1/2 inch off the floor (seems like a bad idea). is there some kinda silicone or padding i can buy to reduce sound? Theres a black lining of padding under the top, but it gets in the way cause when i roll my windows up, it kinda gets stops the windows from rolling all the way up... </TD></TR></TABLE>
seems like your hardtop wasn't installed/adjusted properly. you will have to play around with it to get it right
Old Sep 26, 2005 | 11:18 AM
WowOzYouRock's Avatar
SHUT UP Nishant cuz you dont have a hardtop LMAO HAHAHAH ...
it could be cuz the catchers are worn ... does it rattle or it squeak? if its just squeking, try to oil/lubricant (nishant prefer KY jelly ) on the rubber seals
Old Sep 26, 2005 | 11:29 AM
* B A N N E D *
Default Re: hardtop rattles, wat should i do? (Y2K_S2K)
Damn man you take shots at everyone.
Old Sep 26, 2005 | 02:41 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">Damn man you take shots at everyone.</TD></TR></TABLE>
he won't be happy next time i see him in person
Old Sep 26, 2005 | 03:06 PM
i sure wont ... you crotch snatcher
Old Sep 26, 2005 | 03:17 PM
Nishant's Avatar
how do you ****** a crotch? you must know since you mentioned it
Old Sep 27, 2005 | 01:23 PM
doubleshotz
Paint and Body
Dec 25, 2007 07:50 AM
dragaholic
Aug 27, 2006 08:17 AM
BLU BY U
Honda S2000
35
Aug 4, 2006 02:52 PM
EGfoSheezy
Oct 13, 2005 03:54 PM
crxmadman
Jul 23, 2005 08:52 PM
