Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix...
Old Sep 22, 2005 | 11:01 PM
Y me's Avatar
Default Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix...
which cams will u choose JUN, TODA D OR ENDYN BUMP STIX that u think will give u more whp all motor on a GSR block fully built with 92mm crank 85mm piston with compression 13.8...
Old Sep 23, 2005 | 06:02 AM
JerseySiPOS's Avatar
Default Re: Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix... (Y me)
Depends where you want your peak tq, on top of several other variables.
Old Sep 23, 2005 | 08:33 AM
PURPLETERROR aka BIGMATT's Avatar
skunk pro2's, m22xx's or m24's, also remember there is alot of power to be made with a good valvejob
Old Sep 23, 2005 | 09:03 AM
mikecivichb's Avatar
Default Re: Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix... (PURPLETERROR)
im running crower stage 3's and I love them to death. have the same specs as the toda's vtec killers but still has vtec so it doesnt suffer tooooooo bad in the lower power band
Old Sep 23, 2005 | 09:42 AM
AllMotorMadness's Avatar
skunk pro-2's
Old Sep 23, 2005 | 09:53 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix... (AllMotorMadness)
jun3's have always been a favorite of mine
Old Sep 23, 2005 | 11:10 AM
VtecKiDD's Avatar
Default Re: Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix... (HOOKUPS)
Skunk2 Pro2s
OR
M22XX
Old Sep 23, 2005 | 11:17 AM
newspeedR's Avatar
Default Re: Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix... (VtecKiDD)
Toda D's....
Old Sep 23, 2005 | 11:19 AM
VtecKiDD's Avatar
Default Re: Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix... (newspeedR)
out of the ones you listed, i would run TOda Bs personally. i have nothing against Jun cams, but i have seen dynos of them and they are very peaky, ie, not alot of bottom end power.
i have not seen anythnig on the Endyn Bump Stix
Old Sep 23, 2005 | 04:44 PM
sheepey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">out of the ones you listed, i would run TOda Bs personally. i have nothing against Jun cams, but i have seen dynos of them and they are very peaky, ie, not alot of bottom end power.
i have not seen anythnig on the Endyn Bump Stix</TD></TR></TABLE>
Theres only ONE guy I know that LOVES Endyn but he never shows graphs
Old Sep 23, 2005 | 04:53 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Why did you make another thread basically asking the same question as your last one? Please try to refrain from doing this, it wastes bandwidth
Old Sep 23, 2005 | 06:52 PM
nholmes's Avatar
Buy my cams
Old Sep 23, 2005 | 09:21 PM
chinese acrobat's Avatar
For All motor nothing less than JUN will do.
Old Sep 23, 2005 | 09:41 PM
carboy_honda's Avatar
JUN 4 ,look for my post JUN4 vs Toda B, it goes the same as Toda B in the midrange then at 7000 rpm it took off...
LilCivic04
24
Jun 23, 2008 06:15 AM
Grand
Apr 23, 2005 05:01 PM
Turbo R
20
Dec 18, 2004 01:37 PM
GearheadzAuto
Aug 7, 2004 03:02 PM
[tk4L] Doke
Aug 28, 2002 01:03 PM
