frame damage on del sol?
Old Sep 22, 2005 | 09:38 PM
GetSmoked's Avatar
Default frame damage on del sol?
i found a del sol for cheap. i was wondering if in the pics it looks like it has frame damage. also can you put on the bumper and headlights with a bent radiator support?
Old Sep 22, 2005 | 09:41 PM
hatchish's Avatar
on my eg i have alot of frame damage and all my **** is on there its just not straight looking but u can been fenders and stuff to make it fit the best way is actually geting it fixed
Old Sep 23, 2005 | 07:38 AM
00CivicGirl's Avatar
Default Re: (hatchish)
that damage doesnt look that bad to have bad frame damage..if you want to play it safe, take it to a shop and have them put it on a frame machine and double check that its not bent. If it is and its not much they can pull it out. around here its about $40-$45/ hr on the frame machine
Old Sep 23, 2005 | 08:05 AM
IHateJDM's Avatar
Default Re: (00CivicGirl)
when the hood is popped, look along the top of driver's fender for bends or creases in the metal. If its not bent, there is probably no frame damage, and you can replace the radiator support.
Old Sep 23, 2005 | 08:39 AM
clm's Avatar
clm
Default Re: (IHateJDM)
Any better pictures? It's hard to make out much detail, but from what I can tell it doesn't look to bad. The upper tie bar (support) looks mostly straight, but the main concern will be the bumper support.
Old Sep 23, 2005 | 09:45 AM
GetSmoked's Avatar
this is the only other picture i have. he said he has the bumper but didnt put it on for some reason.
Old Sep 23, 2005 | 03:45 PM
gftgrill's Avatar
it might have minimal frame damage. you'll have to get it on a machine to find out. looks like about 1 - 2 hours max on a frame machine.
you can bend a radiator support with your hands if you need to. if it's damaged alot then I would replace it, but it's just bent, then bend that **** back.
Old Sep 23, 2005 | 04:06 PM
dohcdelsol93's Avatar
Default Re: (gftgrill)
doesnt look too bad. Oh and you can get a new oem front sol bumper 93-95 on ebay for @80 shipped not painted. Mine had similar damage and couldn't find one local
HairyHarry
Dec 28, 2015 03:32 PM
reevear
Jan 19, 2009 05:35 PM
X-Psico
34
Jan 26, 2008 08:14 AM
neophyte210
Jan 8, 2006 09:16 PM
MugenHonda
Aug 30, 2005 06:51 PM
