She rolled over 100k last night...
I'm thinking about doing someting special for her to commemorate the occasion. I got the Yokos balanced and rotated, and I'll probably be stopping off for some new spark plugs and some K&N filter cleaner. Besides that, here's a question: Is it time for a new fuel filter? How can I tell?On my old bug, you could just look at the filterand tell, and it took all of 5 minutes to change it. I don't even know where the fuel filter IS on my GSR! Is it an involved process? Any online instructions? How much can I expect to pay for a new filter?
Any other tune-up suggestions? New clutch at 80k. Timing belt was done at 90k, new plug wires at 95k. That's really been it. Running Mobil1 synthetic (leaking a little) with OEM filter on 91 or 93 octane. I haven't changed my tranny fluid in a while. How often does that need to be done?
Thanks for any help.
Oh, and even with 100k, she' still running hard!
I would change the filter, mine was **** dirty @ 75,000 miles and It made a big difference. Well it put the power back to stock, but unless yours is really dirty you wont notice a big difference. I went with the AEM filter mainly for better flow. I got mine for $80. CHange the tranny fluid NOW!!! it should be done every 15,000 miles and I would use the OEM honda oil for that. THe fuel filter is located by the battery, It will be a black cylinder about 4 inch long with the fuel line attached to the top. Very easy to get at, Just make sure the pressure is out of or fuel lines unless you like gasoline for cologne
. Shouldnt take you more than 15 min to change. Hope this helped a little.
Spawne32
Jul 28, 2009 12:52 PM
brutekiller787
27
Feb 18, 2009 04:10 PM
