*** NEW Teg owner help with Swap**
i just purchased a 94 integra ls with a bad motor.. i have currently a 98 obd 2 gsr motor in my 91 civic hatch.. just curious what am i all going to need to put my b18c1 into the ls.. i tried searching but all i could find was how to ls vtec.. will my gsr dizzy work fine i know your suppse to wire vtec.. but just wondering what ls electricals and parts are compatable with my obd 2 b18c1 thanks!!!
There is, but it requires additional wiring. Things like the distributor will have to be repinned for it to work. Plus you'll have a perfectly good LS harness you can sell to help offset the cost.
is there a easy way to change the ls wire harness to run the gsr.. the wire harness i have is all chopped up quite a bit from the previous owner.. will the ls dizzy internals swap out and work with the gsr dizzy internals?
TRE_
May 4, 2004 08:39 AM
