car starts but
Old Sep 22, 2005 | 05:45 PM
Honda Crx's Avatar
Default car starts but
i just put my tranny back in and when i went to start the car it took alittle while to start, it started but was idling really bad i cant get past 3grand (rpm). backfires real bad, now i have a built d16z6 d series si tranny welded diff.. act 4 puck prtolite flywheel.. running the crx si ecu chipped with a 55grand launch control and 8grand rev limiter and vtec kicks in at 48grand. now when the car is running the ecu is not blinking any codes just stays red. i have spark to all plugs.. sometimes it doesnt want to start. check the timing it was off put it on the mark now the motor surges, seems like the dizzy is bad but im hoping that isnt it. if the dizzy was bad it wouldnt start, i was always throwing code 9 #1 postion cylinder.
now when i pull the tranny the wire for the tps was caught up, i put it back on and still surges and still idles bad. pulled the throttle body off to get a better look at the tps looks fine.. plastic covering is broke but it will still work.. changed the cap and rotor on the dizzy cause when i was doing the timing i got shocked through the cap.. wasnt a good feeling scared the **** out of me.. still not now im too frustrated to even look at my car.
swapped95
10
Sep 29, 2007 09:01 PM
Si Shane
Jun 15, 2007 02:12 PM
slowassciv33
Nov 20, 2006 02:49 AM
Honda Crx
11
Sep 23, 2005 12:30 PM
