help! problems using VAFC
Old Sep 22, 2005 | 05:31 PM
chechin's Avatar
Default help! problems using VAFC
Hi, I'm a total newbie on the use of the VAFC and I was trying to use some bigger injectors (H22A OBD1 Injectors) for my setup because my current ones (Stock B16A Injectors) are too little for high rpm, my setup is on my sig. I was trying to set the fuel map with Narrow Throttle we tried setting at 1000rpm w/ -50% but the injectors are still sending too much gas, I have set Throttle direction UP, cylinders to 4, and Sensor Type 06-06 is there any other thing I have to set to assure the VAFC is correcting the fuel map? Thanks.
b20turbojason
Aug 7, 2004 04:58 PM
Griffin@Camtech
Feb 6, 2004 10:31 AM
1.8T_EG
Sep 16, 2002 12:22 PM
b18c-93
Aug 22, 2002 08:11 PM
