ECU HELP!!
Old Sep 22, 2005 | 04:09 PM
MiMiK's Avatar
Default ECU HELP!!
okay, i have this p28 ECU... it came out of a 96 del sol. it plugs direclty into my 96 civic harness..
--the label reads:
37820-P28-A53
957-100248
i know it's for an automatic. i've been searching and can't get a straight answer whether it's an obd-1 or obd-2 ecu. any help is appreciated.
Old Sep 22, 2005 | 04:35 PM
MiMiK's Avatar
Default Re: ECU HELP!! (MiMiK)
bump. anyone?????
Old Sep 22, 2005 | 05:21 PM
jgalaz1's Avatar
P28's are OBD1
Old Sep 22, 2005 | 05:55 PM
MiMiK's Avatar
Default Re: ECU HELP!! (jgalaz1)
that's what i thought, but the plugs on the back of the ecu are obd2.. i think i'll convert it to manual and pull the 2nd o2 sensor. if it give me a code it's obd2.
Old Sep 22, 2005 | 08:35 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgalaz1 &raquo;</TD></TR><TR><TD CLASS="quote">P28's are OBD1</TD></TR></TABLE>
supposedly there are OBD2 P28's. I cannot confirm that BUT if that P28 plugs directly into his eninge harness (which is a 96) with no conversion hanress then it must not be OBD1 as 96-00 is OBD2A/B
Old Sep 23, 2005 | 10:56 AM
jgalaz1's Avatar
Default Re: ECU HELP!! (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">
supposedly there are OBD2 P28's. I cannot confirm that BUT if that P28 plugs directly into his eninge harness (which is a 96) with no conversion hanress then it must not be OBD1 as 96-00 is OBD2A/B</TD></TR></TABLE>
I've never come across a obd2 p28, and everything in the FAQ section says they are OBD1, but you never know. Take it to a shop and have them look at it. that's probably the best bet.
Old Sep 23, 2005 | 11:19 AM
IHateJDM's Avatar
how many plugs are there? 1996 was first year for federally required obd2 systems. for most hondas, 96 was obd2a, and 97+ was obd2b. If obd2, then you should have 4 plugs going to the ecu, obd1 only has 3.
Old Sep 23, 2005 | 11:49 AM
Ace0246's Avatar
Default Re: ECU HELP!! (IHateJDM)
I can confirm there are OBD-2A P28's. In my friend's 97 Del Sol SI Automatic there was one. We thought it was OBD-1 and that we could easily chip it but we found out differently after opening the cover and finding OBD-2A internals. That ECU should work and if it plugs right in, that's a good sign!
Old Sep 23, 2005 | 11:51 AM
JDM-97CX's Avatar
It is definately an OBD2 ECU if it plugs into your 96 harness.
Old Sep 23, 2005 | 12:00 PM
Relic1's Avatar
37820-P28-A53
is out of a '96 DelSol SI, which means It's OBD2a.
Old Sep 23, 2005 | 12:22 PM
specv5150's Avatar
Dont beleive everything you read even in a FAQ. Everyone on here screams that ALL 96-98 civics are OBD2A and 99-00 is OBD2B...so I went and bought a OBDD2B to OBD1 conversion harness and was quite surprised to see it didnt work. And more to my surprise, my 2000 civic HX is OBD2A
I've never come across a obd2 p28, and everything in the FAQ section says they are OBD1, but you never know. Take it to a shop and have them look at it. that's probably the best bet.</TD></TR></TABLE>
Old Sep 23, 2005 | 12:36 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">Dont beleive everything you read even in a FAQ. Everyone on here screams that ALL 96-98 civics are OBD2A and 99-00 is OBD2B...so I went and bought a OBDD2B to OBD1 conversion harness and was quite surprised to see it didnt work. And more to my surprise, my 2000 civic HX is OBD2A
Show me a usdm 96-98 civic that is not obd2a
Old Sep 23, 2005 | 12:40 PM
IHateJDM's Avatar
Default Re: ECU HELP!! (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
Show me a usdm 96-98 civic that is not obd2a</TD></TR></TABLE>
He's saying that his 00 HX was obd2a, not obd2b like the faq said. Bottom line is that obd2 is a pain in the ***. Unless inspection forces you to be obd2, I would highly recommend switching to the much easier to deal with (and uniform) obd1.
Old Sep 23, 2005 | 12:43 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
He's saying that his 00 HX was obd2a, not obd2b like the faq said. Bottom line is that obd2 is a pain in the ***. Unless inspection forces you to be obd2, I would highly recommend switching to the much easier to deal with (and uniform) obd1.</TD></TR></TABLE>
He also said that not all 96-98s were ob2a, but who cares anyway?
And about the whole switching to obd1, have you ever done it before? I have and it was the biggest pain in the *** EVER, definately not easier to deal with, everything is spliced, the entire engine harness is a cluster **** from hell.
Old Sep 23, 2005 | 12:52 PM
IHateJDM's Avatar
And about the whole switching to obd1, have you ever done it before? I have and it was the biggest pain in the *** EVER, definately not easier to deal with, everything is spliced, the entire engine harness is a cluster **** from hell.</TD></TR></TABLE>
i have done an obd1 swap in obd2 car, which is what i meant. Yeah, it wasn't easy, but well worth it.
Old Sep 23, 2005 | 12:54 PM
JDM-97CX's Avatar
i have done an obd1 swap in obd2 car, which is what i meant. Yeah, it wasn't easy, but well worth it. </TD></TR></TABLE>
Oh yea, it is worth it but there is a lot of bs to deal with along the way.
Old Sep 23, 2005 | 01:25 PM
specv5150's Avatar
Please show me where i said not all 96-98 civics arent OBD2A
Old Sep 23, 2005 | 03:41 PM
transpar_nt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">...oh yeah, and not all 96-98 civics arent OBD2A.</TD></TR></TABLE>
Old Sep 23, 2005 | 04:37 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">Please show me where i said not all 96-98 civics arent OBD2A
I dont see where I said that
Old Sep 23, 2005 | 08:44 PM
scarface50370's Avatar
guys,,,can u run an ob2 ecu on a d15b engine even though it throws a CEL???? cuz i dont have money now for theobd1 ecu, and i have the motor already
Old Sep 24, 2005 | 07:53 AM
MiMiK's Avatar
the ecu plugs straight into my obd2a harness. i guess i'll try having it chipped and if not, it's going up for sale. another delay in my project =/
Old Sep 25, 2005 | 08:16 PM
Relic1's Avatar
that ECU is not chippable. well at least not by the normal means.
There are some out there that can chip an OBD2 ECU.
Old Sep 25, 2005 | 08:44 PM
specv5150's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">that ECU is not chippable. well at least not by the normal means.
There are some out there that can chip an OBD2 ECU.</TD></TR></TABLE>
Yeah I read into it a little bit on pgmfi...but in theend I stopped because getting a P28 (OBD1) was alot easier.
Old Sep 27, 2005 | 08:29 AM
MiMiK's Avatar
oh well... anyone have an OBD1 P28 for sale?
brownsEF
Aug 4, 2021 08:27 PM
Dcaustin156
Jan 9, 2014 06:56 AM
egbaby
Mar 1, 2008 06:52 AM
97civicB18C
Oct 4, 2006 01:01 PM
fatalman
Dec 22, 2003 06:50 PM
