Brake Light Problem
Old Sep 22, 2005 | 04:06 PM
CA6VTEC's Avatar
Default Brake Light Problem
<FONT COLOR="royalblue"> When I engage the brake petal, the lights do not turn on. I checked the sensor on the back and it seems fine. Is there a fuse I can check or something. Before it would work, but the brake light always stayed on. </FONT>
Old Sep 22, 2005 | 05:16 PM
mjc1055's Avatar
Default Re: Brake Light Problem (CA6VTEC)
This might be a stupid question, but did you check the actual bulbs? If their fine, check the fuse box under the dashboard, on the cover of the fusebox theres a diagram that should tell you where the appropriate fuse is.
Old Sep 22, 2005 | 05:19 PM
CA6VTEC's Avatar
Default Re: Brake Light Problem (mjc1055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">This might be a stupid question, but did you check the actual bulbs? If their fine, check the fuse box under the dashboard, on the cover of the fusebox theres a diagram that should tell you where the appropriate fuse is.</TD></TR></TABLE>
<FONT COLOR="royalblue"> Missing the Panel. Lights were changed. </FONT>
b18c1vtecdc2
Sep 2, 2013 09:31 PM
Bobby808
Apr 10, 2005 11:13 AM
BadEH2
Mar 4, 2005 11:48 AM
Sassafrass
11
Sep 4, 2003 01:18 PM
AutoboTxEK
Mar 9, 2002 09:46 PM
