jdm eg6 brakes??? what pads???
Old Sep 22, 2005 | 12:33 PM
Viorent Grip! EG's Avatar
Default jdm eg6 brakes??? what pads???
sup guys...i have a set of jdm eg6 brakes...the rotors can be swapped with gsr..but the pads are not gsr pads.
does anyone have any info on this?
thanks
Old Sep 22, 2005 | 12:34 PM
Relic1's Avatar
fronts or rears?
rears are identical to every other rear disk civic/teg.(non-ITR/CTR)
fronts I'm not sure about.
Old Sep 22, 2005 | 01:40 PM
_BEN_'s Avatar
Default Re: (Relic1)
Maybe they are the same as the 93~94 abs equipped eg's.
If you have another ride pull the pads and go to your local autoparts store and see what looks the same.
Old Sep 22, 2005 | 06:43 PM
Default Re: (_BEN_)
bump
thanks for the info guys...just trying to see if someone here has a definate answer...
jdm eg6 front brakes....what pads????
thanks
Old Sep 23, 2005 | 08:38 AM
Default Re: (dnbCreative.COM)
i bought integra pads...but didnt seem to line up right...
anyone know if there are difference from integra and 99-00 si pads?
Old Sep 23, 2005 | 09:09 AM
Luserkid's Avatar
Default Re: (Viorent Grip! EG)
Go to Autozone/Kragen and ask for different pads, with yours in hand and see which fit.
Atleast thats what i would do Did you try Honda EX pads?
Old Sep 23, 2005 | 09:51 AM
Default Re: (Luserkid)
i have not tried ex pads
i'll give it a try tho...thanks
Old Sep 23, 2005 | 10:15 AM
DSRxCandyh2bEG's Avatar
i think its the same as the civic ex... cause the rotors are the same for an ex as an integra but the caliper is smaller so the pads are smaller... good luck...
Old Sep 23, 2005 | 10:38 AM
Default Re: (Candyh22EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Candyh22EG &raquo;</TD></TR><TR><TD CLASS="quote">i think its the same as the civic ex... cause the rotors are the same for an ex as an integra but the caliper is smaller so the pads are smaller... good luck... </TD></TR></TABLE>
that makes some sense to me..
thanks
Old Sep 27, 2005 | 03:42 PM
Default Re: jdm eg6 brakes??? what pads??? (Viorent Grip! EG)
recently found out that eg6 and ek4 brake pads are the same...
any ek guys out there now about this??
anyone using jdm spoon, endless etc pads on there car 4 lug set up and are from eg6 or ek4?
Old Oct 19, 2005 | 12:35 PM
couple more tries...BUMP
Old Oct 19, 2005 | 12:40 PM
philosofy1's Avatar
92-95 civic ex brake pads
Old Oct 19, 2005 | 01:21 PM
Default Re: jdm eg6 brakes??? what pads??? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">92-95 civic ex brake pads </TD></TR></TABLE>
what is the rotor size for 92-95 ex brakes?
Old Oct 20, 2005 | 09:05 AM
Old Oct 20, 2005 | 10:36 AM
do u have personal experience with fitting these on ur jdm eg calipers?
please let me know
2000EJ8
Suspension & Brakes
Nov 22, 2009 05:58 PM
clem kevin
Aug 11, 2008 03:51 PM
kayin
Sep 26, 2007 01:21 PM
Toneman14
Sep 23, 2005 08:29 AM
EM1Guru
May 4, 2003 07:46 PM
