won't start...
Old Sep 22, 2005 | 12:15 PM
n9tkd9's Avatar
Default won't start...
my crx decided not to start one day. main relay's new, fuel pump's working, fuel filter's new, getting sparks, new battery. anyone have an idea what might of went wrong? it was working fine, over a week then it stopped working. but also i pulled out the head unit during that week of not driving the car. but i checked my wires around the head unit and everything seems to be plugged in and the grounds. so if anyone had the same problem or know what might of went wrong, please let me know. thanks.
Old Sep 22, 2005 | 12:27 PM
Reason's Avatar
Default Re: won't start... (n9tkd9)
Check the fuses, check your battery post because they might be dirty, check the distributor capand rotor too because the screw that holds the rotor on always seems to loosen up.
Old Sep 22, 2005 | 01:19 PM
SinSeven's Avatar
Default Re: won't start... (Reason)
Have you checked the 50amp battery fuse that is located above your shock tower. If you follow the negative wire up to the fuse box you will find the fuse. I had an issue with that a few days back. Also make sure that the car is properly grounded. Another thing to look is the wire that runs from your core support (aka Radiator Support) to your valve cover. In older models this grounding wire is tapped from the subframe to your tranny.
Old Sep 22, 2005 | 01:24 PM
n9tkd9's Avatar
Default Re: won't start... (SinSeven)
yeah, i checked all fuse's and battery terminals. they all seem to be fine, even the ones under dash just double check.
Old Sep 23, 2005 | 08:30 AM
Reason's Avatar
did you check the rotor?
Old Sep 23, 2005 | 12:43 PM
n9tkd9's Avatar
rotor? does that have something to do with starting the car? if so, how should i begin checking it?
carolinacole
Apr 22, 2016 04:29 PM
DACteg
May 15, 2007 06:35 PM
blackie
Jul 27, 2005 02:17 PM
b20vtecEK
Apr 5, 2005 11:45 PM
