what i need to change in order to put D16Z6 in 99' 1.4 civic HB ?
what will swap from the 1.4 to the z6
your mounts except one hole on the drivers upper will need to be elongated
axels
alternator
p/s pump
a/c compresser
cooling lines
which intake manifold did the 1.4 come with is it down draft or side draft ?
how many pin's does the idle air control valve have?
are the o2 sensors 4 wire?
if you use a obd2 sohc vtec ecu you will need to use a knock sensor
like i said before, if you need help sourcing out parts lmk because i would really like to have the crank and rods from the 1.4
axels
alternator
p/s pump
a/c compresser
cooling lines
xkrazyxjbrkerx75
Nov 22, 2009 11:43 AM
sloweredcivic
Jan 4, 2004 07:48 PM
Roadracejunkie
Oct 14, 2003 01:01 PM
