what i need to change in order to put D16Z6 in 99' 1.4 civic HB ?
what are the parts that i need to change in order to put the D16Z6 engine in 99' 1.4L civic HB ?
think you....
think you....
Re: what i need to change in order to put D16Z6 in 99' 1.4 civic HB ? (HB crazy)
dont know but id buy the 1.4 crank and rods off you and help you get parts you need
what will swap from the 1.4 to the z6
your mounts except one hole on the drivers upper will need to be elongated
axels
alternator
p/s pump
a/c compresser
cooling lines
which intake manifold did the 1.4 come with is it down draft or side draft ?
how many pin's does the idle air control valve have?
are the o2 sensors 4 wire?
if you use a obd2 sohc vtec ecu you will need to use a knock sensor
like i said before, if you need help sourcing out parts lmk because i would really like to have the crank and rods from the 1.4
axels
alternator
p/s pump
a/c compresser
cooling lines
xkrazyxjbrkerx75
11-22-2009 11:43 AM
sloweredcivic
01-04-2004 07:48 PM
Roadracejunkie
10-14-2003 01:01 PM
