FS: T3 SUPER 60 TURBO KIT ..
I have a complete turbo kit for sale, I am getting married and i need my car to be more econmical not fast. So this is what i got. Everything was bought brand new and has only been on the car for about 150 miles
1. T3 48/60 Garrett turbo, bought this from down2turbo on ebay, it was rebuilt and looks brand new , NO PLAY AT ALL. comes internally gated at 10psi and adjustable, No leaks
2. SSautoshit manifold. Braced from header flang to t3 flange with gaskets
3. 2.5 steathmode charge pipe kit. All cut to fit and painted phantom grey.
4. Cold air intake with cone filter and inlet welded for catch can
5. Vision oil catch can, all hardware and vaccum hose
6. 2.5 downpipe with 02 bung welded in
7. 8 inch flexpipe with 2.5 inside to be used with downpipe
8. New Magnaflow hi flow cat. 2.5 inlet and outlet
9. 450cc tuner toys correct inject injectors. Plug and play
10. d16z6 oil pan with bung welded in proper postion
11. Stealthmode oil line kit which includes stainless oil feed line, block fitting and oil return
12. Stealthmode oil restrcitor valve
13. TurboXS Blov off Valve welded to charge pipe
14. Jonny Racecar 5 inch Front mount intercooler
15. All couplers and clamps and some extra as well
16. p28 uberdata ecu setup for 10psi basemap
17. Autometer Ultra light boost gauge
18. Autometer Carbon Fiber Air'fuel Gauge
19. One Single guage pod for pillar
20. 2.0 t0 2.5 tunertoys coupler
21. 12 inch slim push pull radiator fan, brand new with all wiring . more room for downpipe
This is setup right now for no ac, but if u clocked the turbo you chould get it to work with AC easly. Everything was bought brand new. And in perfect condtion.
email me if your interested in this setup. if your not running a z6 vtec and have a pre 96 civic or crx then i can i can sell u a z6 head also. so it can run with the ECU
i wont get pms .....
nsh1351@yahoo.com
nsh1351@yahoo.com
not really ..getting out of the honda scene
got a galant vr4 now just trying to get rid of this
thanks for the bump.
but if u wanna buy it straight up then im down with that
i've emailed u numerous times. I sent u money for headlights and corner lights. I haven't heard anything back from you in a few days. Im starting to become pretty leary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">i've emailed u numerous times. I sent u money for headlights and corner lights. I haven't heard anything back from you in a few days. Im starting to become pretty leary</TD></TR></TABLE>
bump, let's get this settled
hey um i could not get to the computer for 3 days and this is what i get?
well anyways the headlights were sent and ebverything is fine
the galant runs 14.3 in 1/4
its basically stock but im running boost at 16psi
im doing a rebuild this winter just order my pistons rings and rods
woohoo
still need this **** gone tho
woohoo
confucioussae
Sep 5, 2007 08:43 PM
