h22 FAL fan??
I Have a 1998 h22a4 with a full size radiator and a FAN. The fan always worked even when cold, but My temp. gauge was starting to move up and the down alittle. SO I relized that my fan wasnt working anymore. Help if you can?
The motor is in a 1991 CRX DX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22a4 »</TD></TR><TR><TD CLASS="quote">I Have a 1998 h22a4 with a full size radiator and a FAN. The fan always worked even when cold, but My temp. gauge was starting to move up and the down alittle. SO I relized that my fan wasnt working anymore. Help if you can?
why was the fan on all the time? was the fan on a seperate circuit?
this post should really be in the hybrid section.. and with a swap like this there are hundreds of half as ways the fan could have been hooked up that would make it hard to troubleshoot wihtout knowing the car inside out.
</TD></TR></TABLE>why was the fan on all the time? was the fan on a seperate circuit?
Its not the fan thats bad because i checked it out and it was fine,but what is up with the temp gauge going up,up up, and then back to normal?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22a4 »</TD></TR><TR><TD CLASS="quote">Its not the fan thats bad because i checked it out and it was fine,but what is up with the temp gauge going up,up up, and then back to normal????? </TD></TR></TABLE>
bad thermostat?
low coolant?
water pump going
bad thermostat?
low coolant?
water pump going
air in the coolant.. bleed your system... about 90% of the time if your temp goes up at stops.. then back down when your driving is because of a air pocket.. bleed it... if youve done it.. do it again...
