2003 Si offset question
Old Sep 22, 2005 | 08:50 AM
Blindeye_03's Avatar
Default 2003 Si offset question
What size wheels fit the si's? I have some rota slipstreams in 15x6.5 sitting on my miata that I want to put onto the civic (if I buy it).
the rotas are 15x6.5 +40ET. What offset does the civic si use? its bolt pattern is 4x100, correct? What about the wheel studs, are they spaced at 1 x 1.5mm or 1 x 1.25mm?
Thanks!
-Justin
...I am new here and I did search but came up short on finding info about the 03 SI... on the newer hatches did they change the bolt pattern to 5 lug? I cant seem to find any info on this... :confused:
Old Sep 22, 2005 | 09:57 AM
Clay@tirerack's Avatar
Honda-Tech Sponsor
Default Re: 2003 Si offset question (Blindeye_03)
Your 03 Si is a 4x100 bolt pattern, just like the Miata. We list the same wheel fitments for both vehicles so they should fit fine. You may want to contact a store that sells the wheel to see if you need different lugs.
Old Sep 22, 2005 | 09:58 AM
Default Re: 2003 Si offset question (Clay@tirerack)
cool, as long as the civic uses 1.5mm and not 1.25 the lugs would work
Old Sep 22, 2005 | 01:48 PM
pingaturbo's Avatar
Honda Offset ET40
Miata Offset ET33
I know this because I have one sitting at work
with some 15CH 5ZIGEN FN01RC et 33. The rims will work but they will past the fenderwell a little bit.
Old Sep 22, 2005 | 01:50 PM
pingaturbo's Avatar
the only ones with the thread pitch of 12x1.25 are the nissan's> Honda/Miata 12x1.5 thread pitch
Old Sep 22, 2005 | 01:53 PM
sweet! Well I know my rotas are +40 offset...thats what Rspeed sold me a year ago.
I guess these will be going on the civic IF I get it... still deciding on an 03 SI or a 06 xA (Id rather have the civic...my friends want me to get the scion).
udm_motorsport
Dec 28, 2009 07:15 AM
loizenin
Mar 12, 2006 08:28 AM
RTW DC2R
Apr 6, 2004 03:08 PM
Hybrid
Acura TL, RL & ZDX
Mar 30, 2004 03:58 AM
Reverend
Feb 25, 2002 09:43 AM
