shifter bushing?
Old Sep 22, 2005 | 07:48 AM
realis9's Avatar
Default shifter bushing?
What is the bushing that help the shifter to not move around? Like if you have the car in 1,2,3,4,5 sometime the level is really loose. Do you guys know what i'm taking about. If the car if in first it looks like it in 3rd or it really loose. I want the shifter to be firm i what ever gear i put it in.
Old Sep 22, 2005 | 09:54 AM
The Kernel's Avatar
Default Re: shifter bushing? (realis9)
Not sure about that. I have the 2 mugen shifter bushings but there's still a bit of side to side play in the shifter.
Old Sep 22, 2005 | 10:25 AM
realis9's Avatar
Default Re: shifter bushing? (The Kernel)
yeah i'm trying to eliminate the side to side play or reduce it.
Old Sep 22, 2005 | 12:11 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Kernel &raquo;</TD></TR><TR><TD CLASS="quote">I have the 2 mugen shifter bushings. </TD></TR></TABLE>
2? my set came with 3 pieces.
(they are for sale btw )
Old Sep 22, 2005 | 12:24 PM
The Kernel's Avatar
Default Re: shifter bushing? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">2? my set came with 3 pieces.
(they are for sale btw )</TD></TR></TABLE>
I remember there was a circular piece that went by the trans end and a rectagular 1 that went right underneath by the shifter.
Where would the 3rd one go??
Old Sep 22, 2005 | 12:29 PM
BDBGoalie1982's Avatar
he's probley refering to the two sides for the round bushing (for the linkage into the tranny)
Old Sep 22, 2005 | 05:14 PM
KOALA YUMMIES's Avatar
Default Re: shifter bushing? (BDBGoalie1982)
No, the 3rd one is that rubber boot like one (looks like a balljoint boot) that goes over the ball part of the shifter.
Old Sep 22, 2005 | 05:41 PM
Dr Pooface's Avatar
Default Re: shifter bushing? (KOALA YUMMIES)
The closest you can get to eliminating the play is the E's kit. After that all the play you feel is in the tranny.
Old Jan 18, 2006 | 03:41 PM
migs's Avatar
Default Re: shifter bushing? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">The closest you can get to eliminating the play is the E's kit. After that all the play you feel is in the tranny.</TD></TR></TABLE>
Where do you get this?
Old Jan 18, 2006 | 04:47 PM
ITR#132's Avatar
Energy suspension shifter bushings are less than $15 and than theres the B&M solid metal bushings.(no idea on the pricing)
Old Jan 18, 2006 | 04:53 PM
migs's Avatar
Default Re: (ITR#132)
This image shows a "CNC machined" product however it still looks urethane, if thats it, thats the one I want!
Old Jan 18, 2006 | 04:58 PM
hayabusa160's Avatar
Default Re: (migs)
some of the play can be caused from the worn out platic bushing at the ball of the shifter. its inside the rubber boot thing.
also the joint itself may be worned and cause play.
but deff upgrade the shifter bushings and work from there. i would replace the plastic one at the ball of the shifter too while the shifter is down.
Old Jan 18, 2006 | 06:43 PM
migs's Avatar
Default Re: (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">some of the play can be caused from the worn out platic bushing at the ball of the shifter. its inside the rubber boot thing.
but deff upgrade the shifter bushings and work from there. i would replace the plastic one at the ball of the shifter too while the shifter is down. </TD></TR></TABLE>
Is this just an OEM part?
Old Jan 18, 2006 | 06:59 PM
Default Re: (migs)
yep oem part.
http://www.acuraparts247.com/p...ch=no
number 8
Old Jan 18, 2006 | 07:08 PM
vivid 02's Avatar
Default Re: (migs)
Where to buy the ES bushing kit for $15?
Old Jan 18, 2006 | 07:10 PM
AntiStock's Avatar
Default Re: (vivid 02)
http://www.summitracing.com
Or, more specifically
http://store.summitracing.com/...h.asp
Part number ENS-16-1101R (red) or ENS-16-1101G (black)
The round one is a bitch to get in...just warning you. It's not split into 2 pieces, and it's hard urethayne so it doesn't give much. Best way to do it is to make sure it's good and lubed up (the bushing and the metal ring on the linkage), interlock your fingers like you're gonna pray, and push it in with your palms (one on the metal ring and one on the bushing). It works, but it takes a lot of effort.
I noticed a good difference, but there's still a little bit of play. Not too much though...and a lot less than with the gum-like OEM rubber ones.
Old Jan 18, 2006 | 08:14 PM
Default Re: (neo_)
its easier to just stick it in a vise and press it in lol thats if you have one
Old Jan 19, 2006 | 05:30 AM
Erik B's Avatar
Default Re: (AntiStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiStock &raquo;</TD></TR><TR><TD CLASS="quote">http://www.summitracing.com
I noticed a good difference, but there's still a little bit of play. Not too much though...and a lot less than with the gum-like OEM rubber ones.</TD></TR></TABLE>
I just ordered mine thanks...I been meaning to get them seeing how I got the tranny out right now and I took the shift linkage off already I ordered it.
tei344
11
Jul 18, 2007 10:36 PM
SoyMilk
Jul 12, 2007 08:39 AM
CTR-GSR
Feb 24, 2006 09:47 PM
wpgcivic
Nov 20, 2004 08:04 PM
zseeanz
Jan 3, 2004 09:04 PM
