new clutch/flywheel, very hard to get into gear............
Old Sep 22, 2005 | 02:36 AM
CivicSiRX's Avatar
Default new clutch/flywheel, very hard to get into gear............
i just installed a 2000 itr tranny to my b16a, and i know this tranny is good because it came out of my brothers car and i drove wit it and it was fine.
along with it, i installed a exedy stage1 clutch and act streetlite flywheel. bled the system 3 times, no bubbles. cmc is good, no leaks. sc is good, no leaks. no air bubbles in system.
car goes into all gears fine with engine off. start the car up, very hard to get into gear. all of them. takes some more then usual strength to do so. upon driving, shifts fine thru the gears, but downshifting is tough. come to complete stop, again very hard to put it in gear.
wat do u guys think? bad clutch? pressure plate? disc? i somehow speculate it but its a brand new real exedy clutch. any help is appreciative.
Old Sep 22, 2005 | 11:23 AM
CivicSiRX's Avatar
ttt
Old Sep 22, 2005 | 11:29 AM
Luserkid's Avatar
Default Re: (CivicSiRX)
Did you try adjusting your clutch pedal?
Old Sep 22, 2005 | 01:55 PM
CivicSiRX's Avatar
Default Re: (Luserkid)
ima try that tonite. good call. hopefully its that. hate to find out its a defective clutch. thanks any other suggestions guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Did you try adjusting your clutch pedal? </TD></TR></TABLE>
Old Sep 23, 2005 | 08:42 PM
CivicSiRX's Avatar
ttt
m0823
Sep 17, 2010 04:21 PM
CLE
Sep 19, 2006 04:30 PM
spidermancivic
Jun 29, 2005 11:02 PM
FLCivic
15
May 31, 2004 09:22 AM
Seann
Jan 31, 2003 02:48 AM
