cable adjusted right for a CRX si
Old Sep 22, 2005 | 02:32 AM
george34's Avatar
Default cable adjusted right for a CRX si
i need to know how to know that a cable for the clutch is adjusted correct. should the leaver ( thats on the tranny) be able to move at all? i'm affraid that my cable is to tight and that i'm going to wear the clutch out. thanks for any help.
Old Sep 22, 2005 | 08:22 AM
george34's Avatar
Default Re: cable adjusted right for a CRX si (george34)
bump.
Old Sep 22, 2005 | 01:06 PM
george34's Avatar
someone help me!!
Old Sep 22, 2005 | 03:38 PM
aka's Avatar
aka
you can't adjust it by looking at it. Adjust it a little bit and then drive and see what it feels like. I liked mine to engage about inch or two off the floor.
Old Sep 22, 2005 | 05:44 PM
george34's Avatar
Default Re: (aka)
how much play should there be in the arm that is on the out side of the tranny. i would say that the clutch engages about 4in from the floor right now. can't u have the clutch engage all the time which will wear out the clutch? i'm afraid that the clutch is going to wear out b/c of the cable not be adjusted correctly.
Old Sep 22, 2005 | 06:15 PM
Crx Jimmy's Avatar
Default Re: (george34)
adjust it till it feels right, there should be no play in the arm it should be taught from the tension of the cable
Old Sep 23, 2005 | 02:36 AM
george34's Avatar
Default Re: (Crx Jimmy)
should a B16 tranny be the same.
Vash121991
May 22, 2012 12:47 AM
BLKHB89
Apr 12, 2008 08:17 AM
pauley01
Jan 22, 2007 10:43 AM
asmallsol
Aug 9, 2004 08:06 AM
