B16a2 swap into EJ8 question
Old Sep 21, 2005 | 10:37 PM
mR. Vash's Avatar
Default B16a2 swap into EJ8 question
I only have two questions, I'm swapping a B16a2 (99-00 Civic Si Engine) into my EJ8(96-98 Civic EX) and I'm buying a jumper-harness so I can run the p2t ecu, will this effect the ref/bar process? and since the motor didn't come with a stock intake, I'm planning on using the one off of my D16y8 would this be a problem for reff'ing the motor?
Thanks in advance, I also have searched.
Old Sep 21, 2005 | 10:47 PM
sicky's Avatar
grammer nawzi
Default Re: B16a2 swap into EJ8 question (mR.Vash)
Don't worry about getting it Bar'd until you get pulled over. I have been running a EJ8 with a 89 B16 and I have had no problems. The car will pass smog, but if I get sent to a Ref I will be fucked with that motor. CA sucks!
Old Sep 21, 2005 | 10:48 PM
mR. Vash's Avatar
Default Re: B16a2 swap into EJ8 question (sicky)
The smog station will still attempt to smog you car after a visual?
kDA
Aug 9, 2006 10:16 AM
ironchef25
Nov 5, 2003 02:58 PM
EclipticX
Sep 29, 2003 05:35 AM
bfong13
Sep 30, 2002 07:05 AM
speshuled619
Jul 4, 2002 10:05 PM
