WHATS THIS NUT THING WITH WIRES???????
Old Sep 21, 2005 | 10:36 PM
nocturnal EG's Avatar
Default WHATS THIS NUT THING WITH WIRES???????
I was changing my tranny fluid today and I noticed that there was a small leak. I looked around and saw this nut thing with black rubber proctecting it and a bundle of wires following the nut. This thing is located on the right side of the tranny (if you take off your right tire, you'll see it). I dont know what it was but it was loose, so i tightened it. Can anyone tell me what this is?...here are the pics...the nut underneath the rubber is 19mm i believe..
Modified by nocturnal EG at 8:33 AM 9/22/2005
Old Sep 21, 2005 | 11:36 PM
Default Re: WHATS THIS NUT THING WITH WIRES??????? (nocturnal EG)
can anyone help me identify this part..pics up...why is it leaking some kind of oil?
Old Sep 21, 2005 | 11:41 PM
fergy016's Avatar
kinda hard to tell, but if it is the bottom of the tranny, that is your reverse switch so your reverse lights come on.
Old Sep 21, 2005 | 11:44 PM
Default Re: WHATS THIS NUT THING WITH WIRES??????? (fergy016)
do you know why it would be loose? or leaking?...i had to tighten it and i noticed that oil leaked from that bolt.
Old Sep 22, 2005 | 04:35 AM
95 integra's Avatar
it is indeed the reverse light and its leaking because its loose and its loose because some dumbass took it out at some point and didnt tighten it back.
Old Sep 22, 2005 | 04:38 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: WHATS THIS NUT THING WITH WIRES??????? (95 integra)
Yup, as they have said, that is the harness for the reverse light. It has a little switch on it on the inside of the tranny that gets depressed when the slider bar hits it. That "flips" the switch and your reverse lights work.
It's leaking because it's loose, and fluid is leaking from the hole.
Old Sep 22, 2005 | 04:49 AM
Quick99Si's Avatar
Default Re: WHATS THIS NUT THING WITH WIRES??????? (shamoo)
When mine was loose, my reverse lights had a tendency of turning on during hard 3-4 shifts. According to my friends anyway.
Adi
Mr_Si-R
Oct 14, 2005 05:18 PM
icon_race_eg
Sep 27, 2004 09:02 PM
sting94112
Feb 22, 2004 01:38 PM
wizzards581
Apr 5, 2002 10:20 AM
