AUTO TO MANUAL CONVERSION ANd LS TO GSR SWAP...
Old Sep 21, 2005 | 06:11 PM
tegrevboy's Avatar
Default AUTO TO MANUAL CONVERSION ANd LS TO GSR SWAP...
Well finally got started on the conversion and swap...from my wrecked GSR To my Auto LS...
AM going to write up w/ pics another DIY...
Well first off i dropped the engine and tranny out of both of them...
Then i removed the Hydraulic clutch lines from the DB8 and installed them on the LS.
And honda was so gracious enough to already put the hole for the slave cylinder and resevoir in the auto ls firewall
And here is the slave cylinder and resevoir going in..
I decided to go ahead and take a stab at removing the bracket that holds the manual shifter in the tunnel... First you drill out the spot welds, then get a heat gun and put just a little bit of heat on it...And with a little elbow grease...
Well take a look...
Here you can see i tried to pry it up and chizel it off didn't work ...I went ahead and drilled them all out..
Here is a picture of the auto ls's shifter hole...
Here i have the bracket out and am fitting it into the LS's auto hole...(sorry forgot to get more pics got involved with getting it out)
Here is the bracket fitted in the whole with a little persuasion..I bumper one side of the auto hole with a hammer and the bracket popped right in and the front two holes lined right up...
WEll that is about it for now..maybe we can put this up as a DIY..HOw TO...
OH yea here is a nice piece that was included in the extra parts that i got with the car...
Modified by tegrevboy at 9:21 PM 9/21/2005
Modified by tegrevboy at 9:28 PM 9/21/2005
Modified by tegrevboy at 10:20 PM 9/21/2005
Old Sep 21, 2005 | 06:45 PM
tegrevboy's Avatar
THere will also be some non vtec to vtec swap pics and info...THought what the hell i am doing both right now anyway..
WEll i know some of might have already seen these pics i posted in another thread a few weeks ago...But here are some pics of the DONOR (green DB8)and the recipient..Red LS...
Modified by tegrevboy at 10:14 PM 9/21/2005
Modified by tegrevboy at 7:47 PM 9/27/2005
Old Sep 22, 2005 | 09:11 AM
tegrevboy's Avatar
come on anyone want to help out w/this.
Old Sep 22, 2005 | 09:28 AM
Steve-'s Avatar
Default Re: (tegrevboy)
auto to manual mount no cut or welding required lol i'm about to get me one lol
Old Sep 22, 2005 | 09:38 AM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
Default Re: (dc4 integi2a 00)
Nice write-up so far.What are you going to do about the gauge cluster?Are you going to strip the whole gsr interior harness and put it in the auto ls?
Old Sep 22, 2005 | 03:25 PM
tegrevboy's Avatar
Default Re: (Scarface928)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scarface928 &raquo;</TD></TR><TR><TD CLASS="quote">Nice write-up so far.What are you going to do about the gauge cluster?Are you going to strip the whole gsr interior harness and put it in the auto ls?</TD></TR></TABLE>
NO probably not strip the whole harness but that would be nice...I am switching the guage clusters... I wish i had the time to switch the interior harness...THat would be a whole lot better...
Old Sep 22, 2005 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegrevboy &raquo;</TD></TR><TR><TD CLASS="quote">
NO probably not strip the whole harness but that would be nice...I am switching the guage clusters... I wish i had the time to switch the interior harness...THat would be a whole lot better...</TD></TR></TABLE>
So a five speed gauge cluster such as a 94 stock 5 speed gsr will just plug right up to the ls auto harness?
Old Sep 22, 2005 | 03:33 PM
tegrevboy's Avatar
That is a good question i would think so ...I don't know what would stop it..Both of the cars i am using Donor and project are OBD-1 so i don't think i should have a problem ..If you know of something let me know...
Old Sep 22, 2005 | 05:46 PM
mjc1055's Avatar
The cluster should work fine, it does in Civics. You could even just leave the LS one there.. the only thing thats slightly bothersome is the gauge selector on the cluster will still be there obviously which is kind of ugly, but who cares...
Old Sep 23, 2005 | 06:11 AM
Default Re: (mjc1055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">The cluster should work fine, it does in Civics. You could even just leave the LS one there.. the only thing thats slightly bothersome is the gauge selector on the cluster will still be there obviously which is kind of ugly, but who cares...
Sounds good!!How about the engine harness are you going to use the stock 94 gsr harness and just pluging it into the ls body harness or you going to use the ls harness and rewire it for vtec,etc.
Old Sep 25, 2005 | 01:52 PM
Bump for inquiring heads who want to know!!
Old Sep 25, 2005 | 02:17 PM
haccord2.2's Avatar
Cool thread! Keep up the good work!
Old Sep 25, 2005 | 03:51 PM
tegrevboy's Avatar
Default Re: (haccord2.2)
Starting back on it this week went out of state this weekend...thanks all...
Old Sep 26, 2005 | 04:54 PM
tegrevboy's Avatar
Okay tonight I i took a look at the cruise control modules and I haven't seen much on these thought maybe this might be the problem i have seen in other threads about the cruise control not working after the conversion ....hence one says a/t cruise control module p75 A/T...And obviously the other says MT P72 cruise control module...anyone have any other info on these.
Modified by tegrevboy at 9:15 PM 9/27/2005
Old Sep 27, 2005 | 06:18 PM
tegrevboy's Avatar
Okay well decided to go ahead and take out the brake and gas pedal from the GSR ...ANd let me tell you either i did it wrong or everyone else just hasn't mentioned how much of a bitch it is...well for anyone wanting a slightly easier way to get it out because it isn't coming out all in one piece with the pedals still attached...here is a pic of the pins that <U>have</U> to be removed, to get it out from underneath the dash...and also the cotter pins have to be taken out first..
Okay well next on the agenda while I have some time to spare, is the issue of the two plugs on the clutch pedal assembly... ONe is for the ignition and the other i believe is for the cruise control well here is a pic of the one for the cruise it is the same color as the one in the M/T its just that it goes to a connector the plugs into the auto tranny well I thought i would just go ahead and remove the pink wire and pin and splice them on to my plug for the clutch pedal assembly...
BTW it is the pink wire on the left side of the plug that you can see... THis wire will be removed and spliced into the wire assembly for the plug for the clutch pedal..which i am hoping will take care of my cruise control...
Old Sep 30, 2005 | 05:05 PM
tegrevboy's Avatar
Ah come one noone with some info about these cruise control modules
Old Nov 13, 2005 | 06:36 AM
dannykointegra's Avatar
how's the swap coming? I'm in the middle of mine right now. OBD2 GSR into my Automatic 94 RS.
Old Nov 13, 2005 | 06:44 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (dannykointegra)
looking good on the DIY, bump for answers.
Old Nov 14, 2005 | 07:35 PM
Default Re: (00IntegrAllmotoR)
Hey tegrevboy, I was wondering how you did the wiring for the vtec? Could you use existing wires that were used for "automatic" for wiring in the vtec by moving them around to correspond with the engine?
smokey2.0
25
Apr 20, 2019 07:49 AM
midenginecivic
Mar 10, 2005 07:25 AM
dn777
Aug 17, 2004 12:11 PM
lsvtecivic
Aug 25, 2003 08:14 PM
