Rear wheel bearings (another bloody knuckle weekend)
Old Sep 21, 2005 | 04:38 PM
Chris F's Avatar
Default Rear wheel bearings (another bloody knuckle weekend)
Well, WGI was a fun weekend, but I got cut short by wheel bearings. Drat! Well, if it wasn't that, it would have been something else. It seems to be high on my "spares to carry" list, along with a dizzy. I'd be better off with an entire Parts Car, but that'll have to wait.
My right rear wheel bearing is in bad shape (loud whirring noise, 1/8th inch of play when I grab the wheel top and bottom.
Anyone had to replace these before? A couple people mentioned it's pretty easy, #2 in the diagram below. I don't know how many people have had this failure, my car only has like 60K miles.
Old Sep 21, 2005 | 06:23 PM
0554's Avatar
Default Re: Rear wheel bearings (Chris F)
pictures always make things look harder than they are. its a fairly easy job. have fun
Old Sep 21, 2005 | 06:24 PM
ZygSpeed's Avatar
Things like this may one either appreciate or want a trailer and tow vehicle!
Sounds like you may need to get a rear hub assembly. ??
Old Sep 21, 2005 | 07:33 PM
KOALA YUMMIES's Avatar
Default Re: Rear wheel bearings (zygspeed)
If you take a lot of pics and writeup on this we'd all appriciate it, wheel bearings are an area I'd like to know a bit more about.
Old Sep 21, 2005 | 07:56 PM
sk8's Avatar
sk8
Default Re: Rear wheel bearings (KOALA YUMMIES)
I replaced my rear passenger about two months ago.
It was easy, just follow the Helm's
Old Sep 21, 2005 | 08:00 PM
uNF$@#!'s Avatar
willard has made a thread with pictures and what he did to replace the front wheel bearings...
i know if one had to take this into a honda shop to fix, they would just replace the entire wheel hub...which is i think the #2 that chris F is pointing to
I havent replaced a rear wheel bearing yet myself...and from the looks of things, it looks like its not that difficult...just bit more expensive than replacing the bearing alone (as in, the front)
Old Sep 21, 2005 | 08:07 PM
Chris F's Avatar
Default Re: Rear wheel bearings (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">i know if one had to take this into a honda shop to fix, they would just replace the entire wheel hub...which is i think the #2 that chris F is pointing to
I havent replaced a rear wheel bearing yet myself...and from the looks of things, it looks like its not that difficult...just bit more expensive than replacing the bearing alone (as in, the front)</TD></TR></TABLE>
Right... It's the whole assembly, and I have 2 in the mail (for better or worse).
This one will be easy, no presses involved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8 &raquo;</TD></TR><TR><TD CLASS="quote">I replaced my rear passenger about two months ago.
It was easy, just follow the Helm's </TD></TR></TABLE>
Glad to hear.
Old Sep 22, 2005 | 09:54 AM
MightyMouseTech's Avatar
This is such an easy job. My best time is 8 minutes from removing the wheel to putting the wheel back on. Helpful tip. Put the parking brake on real tight, and then just remove the caliper/disk/caliper bracket all off together (after removing the rotor screws) saves having to undo the caliper slider bolts and removing the pads.
And yes, I am dead serious about the 8 minutes.
ShinyNewPenny
13
May 28, 2009 06:30 PM
vtfootball54
Jan 22, 2007 04:32 AM
Ill
Sep 12, 2004 07:06 PM
BrandonClaps
Jun 20, 2003 11:20 PM
