b20/vtec?
Old Sep 21, 2005 | 03:53 PM
civic919900's Avatar
Default b20/vtec?
right now im running a 95 civic ex coupe with a jdm b16a swap with dc headers, cai, exhaust, ctr intake cam, vafc2 controller. I want more torque and i was thinkin about doing b20 block with the b16a head. Im not sure if i wanna do that or if i should build my bottom end. If i do the b20/vtec, does anyone know a good b20/vtec kit i should use? Ive seen a couple on ebay with the line, head gasket, and fittings. but idk. im still undecided about b20/vtec or keep the b16. Some input would help.
Old Sep 21, 2005 | 04:12 PM
jax si's Avatar
Default Re: b20/vtec? (civic919900)
http://www.goldeneaglemfg.com is your friend
Old Sep 21, 2005 | 04:13 PM
blaster834's Avatar
pretty easy swap. so i would just do it
Old Sep 21, 2005 | 04:48 PM
EikoU's Avatar
I would go b20/vtec or Ls/vtec..you just won't get the same torque out the b16 as you would with a b20 or ls bottom end...golden eagle sells the ls/vtec conversion kit which is the same one im using on my setup..goodluck..
Old Sep 21, 2005 | 07:53 PM
Well whats really scary is tonight i raced a gutted LS EF Hatch and i missed 4th so bad my vafc told me the highest rpm was 9999 because it does read 5 digits
so that means i revved past 10,000 rpms it didnt blow up tho amazingly. Some one told me I should get my valves adjusted because now i have a slight valve tap. Also I was on the golden eagle site, does anyone hear good things about their products?
Old Sep 21, 2005 | 07:59 PM
jax si's Avatar
well.... donf on this board uses their stuff i believe. that should be enough experience for anyone to trust. if you have doubts ask him ... he owns dfe enterprises out of jacksonville fl. he could build it for you and do port work if needed..that is... for a price of course... but you get what you pay for.
Old Sep 21, 2005 | 08:17 PM
Yea. Ill have to find out. Im still trying to get over the 10,000 rpm rev lol Im so nervous.
Old Sep 21, 2005 | 08:40 PM
RudeBwaiSi's Avatar
I used the Golden Eagle VTEC kit on my motor, absolutely no oil leaks or problems with it.
Old Sep 21, 2005 | 08:46 PM
siregcivic's Avatar
thats exactly why honda put rev governers on there.. my friend and i were screwin around on the freeway the other day i got a single cam vtec in the hatch an hes got a b16 swap.... and he went to shift and throttle got stuck.. now what would happen if that 8200 rev governer wasnt there.. can we say kaboom..
now put your rev governer no higher than 9500.. nobody needs to be revving that high anyway
egcrew02
Feb 1, 2009 07:13 PM
honda_mike
Jan 30, 2008 11:14 AM
e-g-6jdm
15
Nov 11, 2007 03:06 PM
cvclover
Dec 25, 2004 03:37 PM
IJdMCrXI
Mar 2, 2002 08:46 AM
