Lightweight Flywheel Q??
im planning to install my Toda flywheel tomorrow..... was wondering if someone can anwser this Q.?
does the sound of the engine/exhaust note change after the lightweight flywheel is put in? im thinking it does......... can anyone clarify this
Should have zero effect on the sound of the exhaust. In no way does it affect the path of the flow, the harmonics of the exhaust, or the volume of the flow.
Exhasut noise... no
Engine noise... maybe
EX. light-weight valve retainers give off more valve noise that the stock units... I would think that having a less dense flywheel may allow "some" engine noise (that would normally be absorbed by the heavy flywheel) to "escape"
Will
-who thinks the noise difference will not be heard
Will
