Does a dumptube need to flare out to larger diameter if welded to downpipe?
Old Sep 21, 2005 | 10:13 AM
Sprockets's Avatar
Default Does a dumptube need to flare out to larger diameter if welded to downpipe?
...Or, is it ok to run 1.5" all the way from the 35mm flange, as long as it's at least 18" past the turbo and re-merges at a narrow angle?
Old Sep 21, 2005 | 10:41 AM
msmotorsports's Avatar
Default Re: Does a dumptube need to flare out to larger diameter if welded to downpipe? (USE2B16A)
Sounds like that will be fine. No need to flare. However, maximum HP will not be seen with a rerouted Wastegate dumptube. Why not just dump to open atmosphere? Much less work with much better results.
Old Sep 21, 2005 | 01:30 PM
Sprockets's Avatar
Default Re: Does a dumptube need to flare out to larger diameter if welded to downpipe? (msmotorsports)
I've read through all the threads I could find. The FMAX 40hp loss was due to a bad design on their part. If done properly, there should be little to no hp loss. Even if I lose 10hp, it's worth it to me. I hate the sound, and really look forward to having a clean sounding car again.
Old Sep 21, 2005 | 08:23 PM
If sound is you focus than merging with the downpipe with as minimal angle possible will be your best bet.
Old Sep 22, 2005 | 07:26 AM
Sprockets's Avatar
Thanks for the help. Does anyone else have an opinion on my original question?
Old Sep 23, 2005 | 09:58 AM
Sprockets's Avatar
Anyone else?
Old Sep 23, 2005 | 10:16 AM
bubs's Avatar
Don't mean to hijack your thread, but is it really better not to have it going in at an angle? I've been thinking about doing the same thing because I don't like the open dump sound.
Old Sep 23, 2005 | 01:38 PM
lucidvtec's Avatar
i've heard it's only like a 1% loss...runnin a closed loop dump...if done properly
Old Sep 23, 2005 | 01:43 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (lucidvtec)
one guy was running the fmax kit that dumps the wg right in 3" after the turbo... went open dump and gained about 40whp
Old Sep 23, 2005 | 09:56 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubs &raquo;</TD></TR><TR><TD CLASS="quote">Don't mean to hijack your thread, but is it really better not to have it going in at an angle? I've been thinking about doing the same thing because I don't like the open dump sound.</TD></TR></TABLE>
You want it to go in at a narrow angle.
lucidvtec, what size wastegate are you using, and what is the diameter of the dumptube?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">one guy was running the fmax kit that dumps the wg right in 3" after the turbo... went open dump and gained about 40whp</TD></TR></TABLE>
I read about this, but I think it was a test done by FMAX. The link doesn't work anymore. Anyway, 3" is way too close, and that's one of the reasons why there was a 40whp difference.
Right now, my main concern is purchasing the properly sized piping for a 35/38 mm wastegate.
NeEd4Spe3d
Oct 28, 2009 03:19 PM
doood
Nov 28, 2006 09:56 PM
lucidvtec
Jul 12, 2005 11:45 AM
twkdCD595
Sep 29, 2002 10:43 PM
92HB_HB
May 15, 2002 04:48 PM
