code 17 (VSS) still after new sensor...?
Old Sep 21, 2005 | 08:34 AM
jdmbaby's Avatar
Default code 17 (VSS) still after new sensor...?
i got a RHD crx ef-8 throwing up a code 17, vss, its electronic, so i changed it with a working one of a buddies running car, checked the wiring pinouts, all wires hooked up.. now what? i got no vtec and running out of options, its got a stock pw0 b16 ecu, any suggestions.....?
Old Sep 21, 2005 | 09:05 AM
red_EF9Si's Avatar
have you reset your ecu? mine was doing the same thing...no speedo, no vtec. i just reset the ecu and everything was peachy
Old Sep 21, 2005 | 09:21 AM
jdmbaby's Avatar
yeah, ive reset multiple times, just installed V-afc thinking this would control VTEC to come on, but to no success...im thinking maybe might need a new cluster or chipped ecu.., maybe?
Old Sep 21, 2005 | 10:13 AM
APEX CRX's Avatar
Default Re: code 17 (VSS) still after new sensor...? (jdmbaby)
So the speedo doesn't work either?
Old Sep 21, 2005 | 10:24 AM
jdmbaby's Avatar
Yup.....no speedo
Old Sep 27, 2005 | 10:16 PM
jdmbaby's Avatar
anybody....??
Old Sep 27, 2005 | 10:34 PM
IO_303's Avatar
did you try to see if your VSS cable snapped?
Old Sep 27, 2005 | 10:38 PM
jdmbaby's Avatar
Its a JDM cluster, so its Electronic Vss..
Old Sep 28, 2005 | 06:55 AM
crx_88_si's Avatar
check for continuity from the VSS to the cluster. sounds like wiring problems.
Old Sep 29, 2005 | 11:03 PM
jdmbaby's Avatar
i tried out my buddies chipped ecu w/mugen program and the car hauls now.. so im thinking maybe its the cluster..?
mktaylor90
Jan 22, 2011 06:30 PM
Nikademo
Nov 7, 2010 10:50 AM
schwanginpt
Jun 28, 2004 08:05 PM
irtep
Sep 1, 2003 02:07 PM
Kasper.
Sep 12, 2002 05:02 PM
